Bluetooth and iPhone 4 w/ ios5
Old Nov 17, 2011 | 11:09 AM
cc1012's Avatar
I have a 2007 g35 coupe. Since ive upgraded to IOS5, I have had nothing but problems with the bluetooth. It disconnects all the time in the middle of calls and sometimes it doesnt connect at all. Do you think that the bluetooth unit in the car is going bad or do you think it is the ios5 having issues?
Thoughts???
Is anyone else having the same issues?
Old Nov 17, 2011 | 11:48 AM
carlo107's Avatar
I have the ios5 installed on my phone but i have the 3gs. Im not sure if the actual phone makes a difference but the software is the same and i havent had any problems with it. You should try connecting someone elses phone that is not an iphone and see if the same problem happens. If it does it is probably a bluetooth issue
Old Nov 17, 2011 | 12:35 PM
cc1012's Avatar
if i need a new bluetooth module to the car....... does anyone know how much they are?
Old Nov 17, 2011 | 02:21 PM
.cakestar's Avatar
im on 5.0.1 and i do not have any issues at all, just to add my .2
Old Nov 21, 2011 | 02:31 PM
cc1012's Avatar
updated from 5.0.0 to 5.0.1 and it cleared up the issue.
Old Nov 28, 2011 | 08:36 PM
djfarhan's Avatar
^ what he said
Old Dec 2, 2011 | 12:45 PM
cc1012's Avatar
actually didnt fix the problem. It still disconnects at random times.
Old Dec 4, 2011 | 08:45 PM
djfarhan's Avatar
uh oh, damn, what u gonna do now?
Old Dec 6, 2011 | 08:46 AM
cc1012's Avatar
if i need to replace the bluetooth unit.... does that mean I have to replace the whole radio?
Old Dec 7, 2011 | 03:21 PM
Ch'Pok's Avatar
I'm having these kinds of problems in my '08 sedan as well. From what I've seen online, this is a common problem with ios 5. Fords, for example, seem to have a lot of problems. I think it's an Apple issue though, not the radio since my problems started when I updated to ios 5 (for the record I have a Verizon iPhone 4). Also bluetooth worked just fine with the two Blackberries I had before the iPhone.
I have tried erasing the phone from the car's memory and erasing the car from the phone's memory and starting over with the pairing process. This seems to have helped a bit but the connection is still far from 100%. The only thing that definitely works is turning off bluetooth on the phone and turning it on again every time I start the car after the phone has paired. Obviously that's a bit of a pain, so I only do it on longer trips or if I know I'm going to make a call.
I had some problems right after I bought the phone, but Apple soon released an update to ios 4 and the bluetooth connection worked flawlessly until ios 5. I have updated to 5.0.1 and that has not made it any better; maybe 5.1 will fix it.
Old Dec 9, 2011 | 12:18 PM
cc1012's Avatar
^^^^ yea i feel like it is on apples side as well. I am also using a verizon iphone.
Old Mar 8, 2012 | 09:26 AM
Ch'Pok's Avatar
Has anybody gotten the iOS 5.1 update yet? If so, is this fixing the bluetooth problem for you?
Old Mar 11, 2012 | 08:28 PM
cc1012's Avatar
I've upgrades to 5.1 but haven't driven my car yet
Old Mar 13, 2012 | 05:51 PM
cc1012's Avatar
Did the update and it is worse than ever.... The phone disconnects when I start to dial. When I initially paired the phone it was pretty good, I made some calls and it seemed to be holding connection but when I turned the car off and then back on again it started disconnecting and doing all that weird stuff. No one has any reall suggestions on what to do so I guess I'm giving up on it.
On a side not I bought a jawbone icon and it works flawlessly with the iPhone.
Old May 13, 2012 | 10:22 AM
cc1012's Avatar
5.1.1 works even worse
GEDsetG35
Not G35 Related
Jan 29, 2012 04:24 PM
alexcaro
Not G35 Related
Nov 3, 2011 07:59 PM
akachi
Not G35 Related
Oct 19, 2011 08:14 PM
