ribbon cable purpose
Old Nov 28, 2011 | 05:19 PM
TurTLe*'s Avatar
On my 2005 stock bose HU, there is a ribbon cable on the bottom of the radio, had a flat black connector. Goes from internal of the radio covered up with tape to the PCB board in front.
What does that do, ive damaged it, ribbon broke on the radio side, not the part that connects to the faceplate.
But i cant find anything wrong, IE everything seems to work and light up just fine. radio works, lights work, screen works. So whats broken?
Old Nov 28, 2011 | 05:28 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
You must not have broken it too bad, since audio channels from the CD player go through it, as well as other stuff with the faceplate.
Old Nov 28, 2011 | 05:42 PM
TurTLe*'s Avatar
hm.. i dont use the CD player at all tho.
just radio and OEM ipod hook up.
Once i saw the cable seperated from the connector, i was for sure i had a dead radio. Ready to look for a JDM DD. But i plugged it in, CD player did its thing,( made sounds like you were to install a CD in). Nothing worked for a 5 minutes and once the CD player stopped making noise. Radio worked, AC controls worked. Navi worked (its a different system but still)
I'll try the cd player later today.
I straighten out the ribbon cable, it was bent and then i shoved it back into the connector and plugged the connector back into the faceplate side of it.
Old Nov 30, 2011 | 04:14 PM
TurTLe*'s Avatar
CD player works. Sound and ran thru 4 of the 6 cd's. Everything seems GREAT! I guess i got lucky. Not a fan of ribbon cables now tho.
06g35
Feb 14, 2022 05:59 AM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
onlyhuman
Engine - Electrical
Sep 21, 2015 12:28 PM
JustinMKN1
Sep 18, 2015 03:40 PM
