Mounting amps..
Old Jan 12, 2012 | 05:51 PM
Frankieg35's Avatar
Mounting amps..
I have 2 jl amps and wanna hide both of them.. is there room to put them under the carpet and not have a bulge in the carpet?? My plan is to use a thin piece of plywood to mount the amps too..
Old Jan 12, 2012 | 06:44 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
Check the custom audio systems sticky at the top of this forum for some ideas of how you can accomplish something like that.
Basically, you'd have to build a false floor and probably put some ventilation to keep them from overheating if you want them "invisible" like that.
Old Jan 12, 2012 | 06:45 PM
AccordinlySlo's Avatar
I have mine under the left side in the trunk
http://www.soundsensationsauto.com/WhiteG35-191
Old Feb 16, 2012 | 05:22 PM
G. Dizzle #2's Avatar
Does your amp ever over heat being covered all the time or do you have any problems with it there? i was thinking about mounting mine around the same spot if possible
Old Feb 20, 2012 | 02:10 AM
paky786's Avatar
I had problem with mine overheating in the summer under the carpet where the spare goes.. I even added crossflow fan but not sure if it was because of a cheap fan or there is no ventilation. I have no other place to mount them so I'm still looking for ways to make it breath better! Any ideas??????
Old Feb 20, 2012 | 02:16 AM
Frankieg35's Avatar
I'm gonna try and mount mine next to my other amp on my back seat..
Claudiu
V36 Brakes, Suspension, Wheels & Tires
Mar 10, 2018 11:38 AM
sales@czp
Suspension-Vendor
26
Nov 6, 2017 03:04 PM
suby01
Not G35 Related
May 25, 2016 03:07 PM
Claudiu
Sep 26, 2015 01:04 PM
Claudiu
Sep 24, 2015 01:12 PM
