Stereo Diagnosis Help: Head Unit or Amp
Old Jan 27, 2012 | 11:30 AM
Gatling35's Avatar
Lightbulb Stereo Diagnosis Help: Head Unit or Amp
I have an '04 6MT Coupe with the Factory Bose stereo setup. The Stereo system has officially died after several years of functioning funky. My problem is I don't want to spend hundreds of dollars on replacing the headunit only to find out the amp was the problem. Infiniti wants to charge me $128 just to diagnose what the issue is. So I was hoping all the great minds here could help me get a diagnosis of which part is most likely the problem.
Here are my symptoms and these are the same with all sound sources:
  • For years the sound would cut out for 30 secs - 2 minutes a little after being started up cold then play fine the rest of the drive. The display was still on and buttons functioned. The Sound would come back on with a pop from the speakers.
  • Sometimes a good karate chop to the side of the console would make the sound come back on.
  • Recently the sound is almost always out. Stereo Display still functions and it still responds to button inputs. Occasionally there are loud pops from the speakers.
  • Sometimes the sound will come back on for a while at a low volume. Changing the volume makes volume number go up and down on the display but it doesn't actually effect the volume of the sound which remains constant.
My gut says it is the headunit because there is such a buzz about the headunits going bad and not as much about the amps going bad and more about them just being bad. Also, the fact that in the past a swift smack to the console could kick the sound back on.
Thanks in advance for any feedback.
Old Aug 18, 2012 | 07:47 PM
Flax B's Avatar
Whats the issue? Amp or hu? Can someone help i have the exact same problem
Old Aug 18, 2012 | 08:18 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
This one's fairly easy to diagnose, when the sound is out, get a multimeter, set it to A/C and check for signal at the audio signal input wires at the bose amplifier. As the bose uses a low-level signal, you're looking for something around 1v. If there's no signal going to the amp, it's probably the headunit. If there is signal there at the inputs, and no output, the bose amp's to blame.
You can find which wires to check by the pictures and diagrams in this post here - the outputs will be slightly different, but I'm fairly sure the inputs are the same color between coupe and sedan:
https://g35driver.com/forums/audio-v...rams-pics.html
Regardless of which it is, if you can afford it, this is a great excuse to ditch the stock bose system.
Old Aug 19, 2012 | 02:02 AM
Gatling35's Avatar
For me the symptoms above turned out to be the head unit. I purchased a reasonably priced repaired unit on eBay and haven't had any trouble since.
Old Aug 24, 2012 | 01:35 AM
BluIDvl's Avatar
Its the crapy head unit fellas!!! Everyone replaces them unfortunately ......your gonna have to replace the a/c panel too....it will take a poop!!!
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
g.spot
May 9, 2016 10:54 PM
BfloG35
Audio/Video/Electronics
Oct 16, 2015 05:22 PM
BradMD_96
Oct 6, 2015 09:31 AM
