Front Components
Old Jan 29, 2012 | 06:06 AM
KBTOPDOG's Avatar
Front Components
Hello, I have an 05 G35x non-bose and will be installing aftermarket radio and speakers. My question is, is there separate wires for the tweeters at the back of the radio/ factory harness, or is the tweeters incorparated into the front speakers. Why I ask is because I will be amplyfing the doors but wanted to connect the tweeters to the radio, I will be using the Metra 70-7550 harness. Also where can I get a wiring diagram for the stock harness.
Simplifed: If I run front speaker wires and rear speaker wires to an amp, will the tweeters also be amplified. Are they on the same wire as the front door???
Old Jan 31, 2012 | 05:59 AM
KBTOPDOG's Avatar
are the tweeters on the same wires as the 6.5 in the front door in reference to wires behind the radio.
does front left and front right include the tweeters in reference to harness
Old Feb 7, 2012 | 02:03 PM
marteb73's Avatar
are you getting coaxial speakers or components? since you want tweeters and you're amping, Id HIGHLY suggest you go with components. they come with crossovers and sound much much better than coaxials. The price will reflect (tho its worth it).
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
StreetStandard
Suspension-Vendor
Jan 18, 2016 03:36 PM
Daniel k.
Nov 3, 2015 09:52 AM
miata007
Aug 17, 2015 04:36 PM
TreeFiddy
Aug 10, 2015 06:50 PM
