new battery in the trunk
Old Feb 19, 2012 | 01:42 PM
faiz23's Avatar
http://www.ebay.com/itm/220A-HIGH-OU...item3a6061138c
Old Feb 19, 2012 | 05:38 PM
paky786's Avatar
I'm just wondering, how do you get air flow to the amps where the spare tire is? Won't they go into protect mode in summer when it gets too hott?
Old Jul 11, 2012 | 02:09 PM
racercris15's Avatar
sorry for the way way late response guys, completetly forgot about this thread, and im always on g35nyc
Originally Posted by JOKER
what are the options to upgrade?
I always actually thinking about this
https://www.dcpowerinc.com/fit/2005~...51-270-xp.html
might as well go hard
well whenever i do raise up the volume real loud, i drop the back seat to let the air flor from outside, i havent had anyproblems with it getting hot, only once when i was parked up and listening to music for about 1.5 hrs did it go into protect mode......i really want to upgrade the alternator but right now i dont have the funds with child support and all lol...modding the G very slowly
I still havent re done the sub woofer box, its been pounding real hard, all summer long with no issues......i do however wanna upgrade my current 6.5 inch 02 front door speakers to 8inch beyman, my car audio guy found a way to make them fit with the stock door panel, oem bose location, audio sleeper lol
Old Aug 8, 2012 | 09:22 PM
so i finally blew the speaker today
Old Aug 9, 2012 | 11:58 AM
paky786's Avatar
Damn tHose Are the worst moments ever
Old Aug 9, 2012 | 12:29 PM
dead
Brought it home and was figuring out what to do next
Old Sep 18, 2012 | 09:30 AM
update 9/18/12: just finished up new box, 2.237 cubic feet
Speaker should be fixed by tonight and ready to be installed
Old Sep 18, 2012 | 02:38 PM
icekewl's Avatar
least u wont worry bout jumpstarts
Old Nov 28, 2012 | 11:43 AM
so after re coning the sub and then it blowing out again after a month lol, i bought used BTL n2 for now until the new re cone kit comes for my original sub (takes about a month or two to be built).... also lowerd the bass from the amp to make sure i dont blow this out out
going with 2 12inch BTL's in the trunk for the spring, should be ordering the DC power high output alternator within the next week or so
Old Nov 28, 2012 | 02:56 PM
broke_as_ajoke's Avatar
wow takes 2 months to rebuild the speaker? Also, how much does the speaker weigh? It looks heavy.
Old Nov 30, 2012 | 08:09 AM
actually it takes anywhere from 4 to 6 weeks for Fi to build you a re cone kit to ship to you, then to recone it takes about 2-3 days. Speaker weighs 43 lbs, and thats only because it uses Neodymium magnets, if not it weigh 15 to 20 lbs more.
Old Dec 19, 2012 | 04:27 PM
snapped the rearview mirror for the 2nd time lol, just ordered a used one today, gonna see if i can come up with something so it doesnt happen a third time
Old Jan 10, 2013 | 12:58 PM
Bondoed the plastic part of the rear view mirror, going to try and see if this work, gonna paint it also.
Old Mar 15, 2013 | 09:10 AM
2-1-13 update: got 8inch beyma neodymium door speakers installed
3-9-13 update: bout a ipad mini, started rocking it in the G custom mount lol
not doing 2 12inch subs anymore, going to just stick with 1, still haven't ordered the alternator
Old Mar 15, 2013 | 12:27 PM
  #30
drozzy's Avatar
I must have missed the part where you explain how you blew a 2000w rated sub with a 2200w amp. "Lowered the bass"?
1. Where's your LPF set at? What slope?
2. What's your HU, and what are the preamps rated at? (don't know your system)
2a. How high is the non fading (sub) preamp level set at?
2b. Are you using bass boost from the HU, or any loudness-type feats?
2c. Using a test tone, how high can you go on the volume scale before the signal clips? (i.e. did you remain under unclipped HU power)
3. What's the amp gain/sensitivity scale i.e. lowest & highest voltage levels taken in?
4. Did you build your ported enclosure within the parameters set by Fi? What's the tuning freq of the port?
If you have a hard time answering any of those questions, and considering you're running a 200+ amp system without a HO alt, don't be surprised you're having issues - sorry.
