new battery in the trunk
Old Mar 15, 2013 | 01:03 PM
  #31
faiz23's Avatar
Make sure to budget for hearing aid down the road and look into picking up a set of ear drums.
Old Mar 25, 2013 | 11:05 AM
  #32
racercris15's Avatar
Originally Posted by drozzy
I must have missed the part where you explain how you blew a 2000w rated sub with a 2200w amp. "Lowered the bass"?
1. Where's your LPF set at? What slope?
2. What's your HU, and what are the preamps rated at? (don't know your system)
2a. How high is the non fading (sub) preamp level set at?
2b. Are you using bass boost from the HU, or any loudness-type feats?
2c. Using a test tone, how high can you go on the volume scale before the signal clips? (i.e. did you remain under unclipped HU power)
3. What's the amp gain/sensitivity scale i.e. lowest & highest voltage levels taken in?
4. Did you build your ported enclosure within the parameters set by Fi? What's the tuning freq of the port?
If you have a hard time answering any of those questions, and considering you're running a 200+ amp system without a HO alt, don't be surprised you're having issues - sorry.
i cant answer all of them, my audio guy did all the tuning,
headunit is pioneer DEH-P980BT
and yes i built the box within the parameters set by fi, tuned to 32 HZ
i know i need the alt, just havent gotten it yet.
As far as the issues comment, im not having any issues, reason why i think it blew the second time is because it wasnt reconed properly.
Old Mar 25, 2013 | 11:24 PM
  #33
herrschaft's Avatar
What gauge wire are you using for the rear battery?
Old Mar 27, 2013 | 12:43 AM
  #34
0 gauge
Old Apr 3, 2013 | 12:37 PM
  #35
bmpnride's Avatar
I hope you dynamat the trunk well. That seems like overkill. I have a 10" IDMAX in modded 4080 box pushed with 750watts and I cracked not only my rearview mirror base 2x but also cracked the windshield a few times. I bet it sounds good though.
Old Apr 4, 2013 | 12:11 PM
  #36
trunk hasnt been dynamted yet, going to be doing that soon. I just ordered the alternator today. Really you cracked the windshield a few times?... i havent cracked that yet lol, i get alot of roof flex though alot alot. did u dynamat urs?
Old Apr 4, 2013 | 09:11 PM
  #37
bmpnride's Avatar
I had my trunk lid dampened with fat mat. Its cheaper than dynamat and works great. I now gave the whole bottom of my trunk lined as well. The windshield I cracked was not oem. I have since had it replacedso it may have been cheap glass. The rearview mirror in our cars do suck. They are so heavy. I'm afraid i will snap the base again.
Old Apr 5, 2013 | 09:11 AM
  #38
Wrathernaut's Avatar
Gentle Manne of Leisure
Dynamat is probably the most expensive and among the worst of the batch of vibration dampener. Fat Mat is one of the better brands that is easy to get your hands on.
Using a vibration dampener like dynamat or fat mat is unnecessary and expensive. Only about 25% of each panel needs to be covered. The dampener is the equivalent to touching your finger to a ringing bell, you don't need to touch the whole thing to stop vibration. To stop noise going through, you need to lay down a barrier of a combination of closed-cell foam and mass-loaded vinyl.
Old Apr 5, 2013 | 09:15 AM
  #39
faiz23's Avatar
Quality sound deadening products
http://store.secondskinaudio.com/
http://www.raamaudio.com/
Old Apr 8, 2013 | 11:23 AM
  #40
yeah dynamat is overpriced, i was thinking about using some sound deadner from home depot, about 12 dollars a roll, seen alot of people on youtube use it. what kind of foam r u talking about?
Old Apr 8, 2013 | 01:32 PM
  #41
That home depot stuff is fine to use on the floor, but do not try and use it in doors or anywhere that gravity will pull it away from the surface.
The foam is vinyl-nitrile closed-cell foam, like this:
Basically, just take 15min and read through the main page of this site:
http://sounddeadenershowdown.com/
It will give you all the knowledge you need to start making good decisions about sound deadening. The guy who runs it is awesome too. Started out just comparing products, but by doing so, got in touch with the manufacturers and had stuff made that exceeded whatever else was out there.
Old Nov 7, 2013 | 08:04 AM
  #42
Still havent done any sound deadning or ordered the alt FML. System sounds great but i think i need more bass lol its an addiction.
Old Nov 7, 2013 | 09:02 AM
  #43
Urbanengineer's Avatar
Add sound deadening bud. It does a lot for the quality of bass and the loudness, and you don't have to run as much power!
Old Nov 7, 2013 | 09:11 AM
  #44
yeah i know man its on the list by spring hopefully
Old Nov 26, 2013 | 09:51 AM
  #45
so my rear view mirror snapped again this weekend lol
KruZZe
Feb 27, 2023 05:04 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
g.spot
May 9, 2016 10:54 PM
dcsbh1
Oct 1, 2015 03:15 PM
