Will my factory Bose speakers work with a aftermarket HU?
Old 02-21-2012, 11:24 PM
westbank23's Avatar
I'm getting a double din soon and Wanted to know if It will work with my factory Bose speakers or would I have to replace them and go aftermarket?
Old 02-21-2012, 11:36 PM
westbank23's Avatar
Old 02-22-2012, 09:16 AM
Wrathernaut's Avatar
Gentle Manne of Leisure
Received 1,038 Likes on 611 Posts
The speaker work fine, it's the amp you have to worry about.
I've no experience with that adapter, but the PAC ROEM-NIS2 has been used by many with good results.
Read the first three posts on this thread to answer many of your other questions you didn't think to ask:
https://g35driver.com/forums/audio-v...urce-list.html
westbank23 (02-22-2012)
Old 02-22-2012, 01:09 PM
westbank23's Avatar
Another question
Is it necessary to remove the shift **** to install New HU?
I have a 6mt
Old 02-22-2012, 01:37 PM
GR6RR's Avatar
By-pass the bose amp!!! It'll sound so much better
Old 02-22-2012, 01:58 PM
westbank23's Avatar
Ok So I ordered my headunit from crunch field and they are giving me this for free http://www.crutchfield.com/p_1207075...s.html?tp=2977
And I also ordered the metra kit that comes with the wiring harness.
Now if I order the the PAC ROEM-NIS2 I won't be needing the harness I got for free and the metra kit harness right?
I would just connect the PAC ROEM-NIS2 to my new HU then connect to the factory oem harness....??
Old 02-22-2012, 02:03 PM
westbank23's Avatar
if I do that would i have to rewire all the speakers?I remember having to do that with my Infiniti I30 Bose speakers.
Im going to repace my Bose speakers by the end of this summer with aftermarket but in tge mean time I need some sound ASAP.
Old 02-22-2012, 02:27 PM
westbank23's Avatar
Nevermind I actually got some time to read your thread Wrathernaut lol.
Really great info
Old 02-22-2012, 02:54 PM
GR6RR's Avatar
I'm not sure if I did it the right way, but it worked...
In the trunk, there is your Bose stock amp. Cut all the wires and reconnect them without the amp. I didn't re-wire all the speakers.
Old 02-22-2012, 03:36 PM
westbank23's Avatar
Ok I see I did something like that on my old 5th gen prelude that had a factory amp but there were some wires that didn't need to be connected.
Is there a DIY thread for doing it this way?
My searchs came empty
Old 02-22-2012, 04:35 PM
GR6RR's Avatar
^ It took me like 2 days to find some info on this swap. It was best found through Google....
all I need was the wire color scheme and reconnect all the wires correctly.
Before I did it the way you are wanting to do it.
Install AM HU and take care of removing the bose amp later... but.. i had to take the HU out as well to replace the adapter that we originally used for the Bose amp. didnt really replace the adapter, but I had to cut the box thing off the wires and reconnect w/o that.
Alot of work, but as I'm reading, I'm sure you know a few things about this and was just trying to make sure before getting to work.
Good Luck,
it took me awhile.
Old 02-22-2012, 05:33 PM
westbank23's Avatar
Ok thanks yea Installed a bunch of systems in me and a few of my freinds cars mainly Hondas and acuras.but on the g35 it seems like its going to be a Lil more work with all the extra accessories needed.
I'm going to try doing it with the PAC ROEM-NIS2 and see how it sounds before I start cutting wires.
Old 02-24-2012, 09:40 PM
Top Teke's Avatar
Westbank, just read through the stickies at the start of this forum. All your questions will be answered. Everything you need to know is in there. You could probably build your own bose amp with all the information listed in Wrathernaut's posts.
Old 02-25-2012, 05:32 AM
Another question
I have a 6mt
No, it is not necessary to remove the 6MT's ****.
Old 02-25-2012, 02:36 PM
westbank23's Avatar
ok so i ordered everything i need and i should arrive soon going to install it all by the end of next weekend.
list of stuff i ordered plus the prices
from CrutchFeild:
Sony 7in XNV-770BT-$649.
nissan antenna adapter-Free
nissan/infiniti wire harness and amplifier integration-Free(wont be using this)
Metra double din kit-$99.99
from amazon:
PAC SWI-PS Pioneer and sony universal steering wheel radio interface-$39.39
PAC ROEMNIS2-$29.08
BOYO VTL420 CCD CAMERA-$88.98
shoutout to wrathernaut for that great info the sticky section
Quick Reply: Will my factory Bose speakers work with a aftermarket HU?
