Aux only adapter?
Old 03-16-2012, 01:26 PM
Nappy's Avatar
Aux only adapter?
I'm (hopefully) trading in my car in less than a year, so I can't really justify spending money on a double din install. What I'm looking for is a cheap solution to get me auxiliary sound for the next few months. I keep seeing two options:
1) Systems that are ipod interfaces that include an aux input for $150+.
2) Systems that are an fm modulated aux only...which I assume don't sound that great.
Is there anything that is not an antenna bypass for $100 or less? I don't need ipod/iphone hookups...just the aux cable.
Old 03-16-2012, 02:57 PM
That's G's Avatar
I've been searching for this exact same solution. Hopefully some of the knowledgable folks on this forum can chime in on this one
Old 03-17-2012, 01:41 AM
Top Teke's Avatar
From what I've read it's more expensive to add an aux input to factory bose than to just replace the HU. If you get the Metra and don't mind losing bluetooth you can do it for ~$300.
Old 03-17-2012, 11:41 AM
Wrathernaut's Avatar
Gentle Manne of Leisure
Received 1,037 Likes on 610 Posts
Old 07-12-2012, 01:22 AM
NYT's Avatar
NYT
NYT is offline
Originally Posted by Nappy
I'm looking for is a cheap solution to get me auxiliary sound.
Add me to the list waiting for someone to chime in also
Old 07-12-2012, 03:15 AM
You're going to be waiting a very long time. These cars have been out for about a decade now and the cheapest options are over $100.
Wired FM modulators really sound good though. Better than any FM station, and honestly, unless you're using 256kbps MP3s or higher quality audio as your source, you won't hear the difference.
Or you could just upgrade your radio.
Old 08-14-2012, 07:13 AM
NYT's Avatar
NYT
NYT is offline
^ Thanks. I know upgrading the HU is best, but then is starts getting expensive, I might lose some of the factory controls (BT, steering wheel, etc?) and I'm more go than show, so I'm OK with a stock-ish interior/sound.
Does our Bose have a connection for a CD changer at the back? I read that many car CD players have this and that adapters are available that can provide RCA connections, which would allow for a high(er) quality Smartphone hook-up. Any chance our Bose unit also has some type of expansion port like this?
Old 08-14-2012, 04:28 PM
The satellite connections on the factory harness are the only "expansion" port, something like the ISNI-531 is what you're looking for to add an AUX port.
NYT (08-14-2012)
Old 08-14-2012, 04:45 PM
NYT's Avatar
NYT
NYT is offline
Thanks Wrathernaut!. Now for my last 2 noobie questions:
1. Is a satellite connection better than a wired FM modulator?
2. How do I know if my Bose has a sat connection? (My '07 G Coupe 6MT was imported from the US)
Old 08-14-2012, 04:51 PM
Jairen's Avatar
An AUX adaptor is cheap.
This is what I have and it works fine. Plugs straight into the factory HU and gives you two inputs.
NYT (08-15-2012)
Old 08-14-2012, 05:35 PM
Yes, the satellite connection is going to be better. Probably worth the $30 or so difference if you never plan to upgrade your radio, but since the radios in these cars go out frequently, it's my opinion that your money is better spent saving towards a full radio replacement. Even the dirt-cheap single-din radios have aux inputs these days.
The only g35s that don't have the sat connection are the early '03s.
Old 08-15-2012, 06:58 AM
NYT's Avatar
NYT
NYT is offline
This is almost perfect... Do they make one with USB? It would be nice to power my phone stealth and not have an exterior cable going into my lighter socket.
Is the install do-able for a noob?
Edit: On the PAC website I could only find this ISNI531 model, which has RCA and 3.5mm:
http://www.pac-audio.com/productDeta...&CategoryID=45
Old 08-15-2012, 05:36 PM
I think the AAI-NIS is the previous generation device. Still available in some places though.
They don't do one with USB, since USB isn't an audio-carrier, it would require a whole lot more to get audio through it - decoder, some way of browsing files, rather than just passing the analog signal through the right wires at the right levels. They have stuff like that for iPod, since it's one device, rather than the millions of USB devices out there that are all different in file structure, encoded filetypes and such.
Old 08-16-2012, 06:05 AM
NYT's Avatar
NYT
NYT is offline
What if I spliced the lighter socket wires and added a 2nd lighter socket behind the dash/stereo? This way I could plug in my lighter socket-to-USB charger and run it stealth behind the dash to my phone mount.
Is this doable/safe/realistic option?
Old 08-16-2012, 06:54 AM
Yeah, piece of cake, but if you're going that far, just disassemble the socket-to-usb charger and run wires that tap into the wires connected to the factory lighter socket. Less bulk to try and hide, and I trust soldered wires with heatshrink on them much more than I trust a cigarette lighter plug to stay in a socket over an extended period of time.
Quick Reply: Aux only adapter?
