need help for headunite wiring
Old Mar 26, 2012 | 11:55 PM
lf1netjohnny's Avatar
I get a aftermarket headunite-JVC KW-HDR81BT
also I get the Metra 70-7551
I do the research on how to wire the hardness, but I am still confused on some parts
from the Metra 70-7551:
where should i connect the "AMP TURN ON (12V+)"(blue with white strip)
"AMPLIFIER GROUND"(black with white strip)
"POWER ANTENNA"(blue)
"CHASSIS GROUND"(black)
from the JVC headunite
there is one for auto antenna, where should i connect this?
thanks for helping!!!!
Old Mar 27, 2012 | 04:19 AM
Wrathernaut's Avatar
Gentle Manne of Leisure
Chassis ground gets grounded to the metal of the vehicle.
If you don't have the bose amplifier, don't worry about amp turn on or amplifier ground.
Connect power antenna to auto antenna.
Old Mar 27, 2012 | 05:25 AM
i have the stock bose amplifier......so what should i do
Old Mar 27, 2012 | 09:31 AM
If you have the stock bose amplifier, you have the wrong wiring harness.
Get a PAC ROEM-NIS2 and start over.
Old Mar 27, 2012 | 03:09 PM
Hi thanks for all your reply.
Wrathernaut didn't you use the metra 70-7551 on the bose amp in your post?
so I should get the PAC ROEM-NIS2 instead of metra 70-7551?
Old Mar 28, 2012 | 01:04 AM
Yes, I did use it, but most people haven't had good luck using it. I used it in mine to confirm/deny that it was possible that it'd work, but enough people wired according to my video had bad results, so I don't recommend it at all anymore.
Since I replaced the POS waste of space sound-quality killing bose amp, it didn't matter that I used the 70-7551.
Old Mar 28, 2012 | 01:58 AM
Top Teke's Avatar
Hey Wrathernaut, did you actually replace the Bose amp with another or just delete it out?
Old Mar 28, 2012 | 03:24 AM
OK, thanks you
I just order the PAC ROEM-NIS2
waiting for it!!!
ha
Old Mar 28, 2012 | 08:17 AM
I deleted it with extreme prejudice. Removed from the car, disassembled and thrown in a box somewhere.
The only bit of factory audio remaining in use in my car is the wiring to the front door speakers.
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
prinny
Nov 22, 2015 11:07 PM
9tray turbo
Sep 29, 2015 10:22 PM
the93owner
Sep 28, 2015 10:37 PM
