Speaker Mounting Depth?
I have an 2003 Infiniti G35 Coupe -- can anyone tell me me the speaker mounting depth for:
I would like to install in the front a pair of Infinity Kappa 50.9cs (woofer top-mount depth: 2-3/16), in the rear passenger seat side panel a pair of Infinity Kappa 52.9i (top-mount depth: 2-3/16"), and in the rear deck a pair of Infinity Kappa 692.9i (top-mount depth: 3-5/16")
Will these fit? It would be nice to know the available speaker depth in the various locations BEFORE I purchase the speakers.
Any info would be appreciated, please.
Thank you,
Cameron
- Front door
- Rear seat side panel
- Rear deck
Thank you,
Cameron
I have some CDT ES-6 mids in the door and they are 2.75" deep and I have no issues.
I have a Sedan but i think the depths are the same.
Either way you will need a spacer. I have a 3/4" spacer.
check with crutchfield.com. there techs are really good about speaker depth
For those people whom might be interested, I removed the door trim panel and also the rear seat side panel and inspected the speakers and speaker cavities to measure the mounting options. Here are my findings:
Front Door Speaker (6.5"):
Tweeter (1"):
Rear Seat Speaker (6.5"):
Rear Deck Speakers (6x9"):
Cameron
- Speaker (woofer) depth: 2.5" -- this is height of the entire speaker assembly measured from the back of the speaker (magnet) to the front/top edge of the plack plastic housing that holds and mounts the speaker.
- Speaker (woofer) cavity depth: 2.5" -- measured from the door panel to the shallowest part toughing the window glass.
Tweeter (1"):
- Tweeter height: 11/16" -- physical hight of tweeter measured front to back
- Speaker (woofer) cavity depth: 1.5" -- measured from the speaker mounting bracket to the shallowest part toughing metal side panel.
- Black ring that holds the speaker: 1.25" wide (height)
- Space behind speaker: 3/16 ~ 1/4" -- when the speaker is mounted there is about a 0.1875 ~ 0.25" space between the rear of the speaker magnet and the metal side panel behind it.
- Not yet measured
Cameron
Claudiu
V36 Brakes, Suspension, Wheels & Tires
Mar 10, 2018 11:38 AM
DEMoLITIoN
Audio/Video/Electronics
Apr 20, 2016 06:57 PM
