amp recommendations
Old Apr 22, 2012 | 11:06 PM
NgoFrickinWay's Avatar
Anyone have thoughts on MB Quartz 4-channel amps? Figured I'd ask here than to start a new thread.
Old Apr 22, 2012 | 11:42 PM
sandaluv's Avatar
alpines have differential balance imputs according to a guy on bimmerfest. im looking into those. i havent found anything on mb quarts though.
Old Apr 23, 2012 | 01:44 AM
Wrathernaut's Avatar
Gentle Manne of Leisure
Originally Posted by sandaluv
thnx guys ive been searching since wrathernaut suggested JL to me and today i found a used 1 on CL. JL 300/4 $200 bucks "immaculate" . thoughts?
Sounds fine to me, but not being able to look at it
Just check the screws holding the thing together closely for signs of the unit being opened and messed with.
Old Apr 23, 2012 | 08:11 AM
sandaluv's Avatar
got it thnx. ill let you know how long my stock sub can take the power b4 it "blose"
Old Apr 23, 2012 | 09:37 AM
Top Teke's Avatar
I'm going to be using a Rockford Fosgate T1000-bdCP.
edit: I think this post was supposed to go to another thread... sorry..
Last edited by Top Teke; Apr 23, 2012 at 04:04 PM. Reason: That's what I get for being on driver at work.
Old Apr 23, 2012 | 10:31 AM
sandaluv's Avatar
TT are you doin stock setup like me? if not, what are you gonna run? after hrs of research im open to all ideas at this point.
I'll prolly just go with all new speakers and sub like wrathernaut suggested sooner rather than later.
Old Apr 23, 2012 | 10:41 AM
sandaluv's Avatar
Thumbs up
dumb question. i just looked at your equipment. you are way past the stock arena
Old Apr 23, 2012 | 10:56 AM
sandaluv's Avatar
you know how when you go to costco for just for toilet paper and you walk out of there with a big screen tv ? thats how i feel with this audio stuff. doing your homework is good but you quickly discover stock is not good enough. my wife thinks I'm obsessed haha. but I love my car and plan to keep it for a while. this may sound snobby but I won't let anybody touch it. when It was under warranty I would put a "do not wash"sign on the dash and now i do all the maintenance with help from the forum. thnx guys
Old Apr 23, 2012 | 11:35 AM
Top Teke's Avatar
All I can say is that the more work I do the more my car means to me. Although I've definitely let friends drive it here and there. Haha.
Old Apr 23, 2012 | 11:51 AM
sandaluv's Avatar
I completely agree. whenever I do a full detail,engine included ,it feels like a new car to me and I baby it just a little more.haha it's weird. my brother who races alfa romeos,can't wait to get his hands on my car but no way. whenever I'm in the car with him it's 1 hand on the dash and another on the door handle .imagine what it would be like without me in the car. he most definitely would have it sideways almost immediately. haha
Old Apr 25, 2012 | 12:01 AM
sandaluv's Avatar
Originally Posted by Wrathernaut
Used amps are usually just fine, subs *can* be ok, but I'd probably stay new there. Full-range speakers, I'd probably go new.
You can get the JL 300/4v2 for just over $300 on amazon. It works very well for 2-channel mode (how I have it set up). You'll need two RCA splitters if you're using this 4-channel amp in 2-channel mode (and for most other 4-channel amps), but they're cheap.
please explain what is an rca splitter and how would i connect this to my existing speaker wire.
can you please give me a quick rundown of what wire goes to what?.thnx
Old Apr 25, 2012 | 02:30 AM
Top Teke's Avatar
It's an RCA cable on one end and 2 RCA cables on the other. Like a "Y."
A 4 channel amp requires 2 pairs of RCAs and you'll only have 1 pair. A splitter will give you 2 pairs.
Old Apr 25, 2012 | 08:13 AM
sandaluv's Avatar
thanx Top Teke, sorry for asking such dumb questions, but i thought the bose system has no rca. can you clarify. thanks TT
Old Apr 25, 2012 | 12:38 PM
jsolo's Avatar
A bit off topic, but can this concept of differential balanced amp idea be explained further? Are they simply using a common ground for multiple channels instead of individual +/- for each?
Old Apr 25, 2012 | 01:14 PM
  #30
Top Teke's Avatar
No problem. You are correct, it does not have RCA outs. You would need to use a line level converter. This sticky explains the rest of the details on how to add a sub/amp while keeping the stock Bose HU.
The physical input/output is the same. Here's a rundown on balanced audio from Wikipedia.
