my horn doesn't work!!!!
Old Apr 22, 2012 | 02:47 PM
Carmelo's Avatar
when i press my horn i can hear the relay click. and everything seems to be connected.
when i bought the car the horn was disconnected for some reason. do i need to buy a new horn? and if so do i have to buy both?
Old Apr 23, 2012 | 01:46 AM
Wrathernaut's Avatar
Gentle Manne of Leisure
Get a multimeter, and check the harness going to the horn. If it registers 12v at that harness, it's your horn that's bad. Horns are horns, so if it's that, just replace it with whatever horn you fancy, plug it in and mount it in there.
If it doesn't register 12v at the harness by the horn, then you've got more diagnosis to do than I can explain here.
Old Apr 23, 2012 | 02:10 AM
NATH_19's Avatar
+1 get a multimeter or borrow one.
The wires from the multimeter are 2 colors, RED + or BLACK -
Place each ends to the ends of the wires going to the horn. Have someone press the switch at your steering wheel... if you have an analog multimeter and connected wrong the gauge will go to the left... if yes then switch the red and black prong of the multimeter.. it should read 12V +/- if you have a digital multimeter it should read +12 or -12... then you have voltage... if yes... your horn is broken..
If it does not register 12V.. check your fuse
goodluck.. honk honk..
Old Apr 23, 2012 | 09:47 AM
Carmelo's Avatar
I guess I need a new horn, the meter read 12v when pressing the horn! Thanks guys.
But will I need to buy both horns?
Old Apr 23, 2012 | 10:34 AM
NATH_19's Avatar
If both lines have 12v and either one of your horns is not working then yes.
go to a scrapyard.. You can find different kinds of horns... For cheap
D1dphresh
Aug 7, 2015 06:10 PM
Rehman2009
Jul 27, 2015 03:23 AM
newg37
Jul 26, 2015 09:32 AM
