Tweeter Issue
Old Apr 28, 2012 | 04:35 PM
ImElvis's Avatar
Tweeter Issue
sup g35 drivers. i drive an 04 coupe with the bose package. few months ago, my driver side tweeter started crackling so i replaced only that single tweeter with a $8 set off ebay. when i play CD the driver side tweeter is off and the passenger one operates as it should. then when i switch to tape( i have a cassette to aux adapter) or radio, the driver side tweeter plays music as it should as well. i have tried adjusting my balance but when i add more to the left.. the driver side tweeter still doesn't play any sound at all. anyone know a fix?
Old Apr 29, 2012 | 01:59 AM
Top Teke's Avatar
Check your wiring, you may have a short. If the wiring's good check your tweeters, you have an $8 set from eBay.
Old Apr 29, 2012 | 04:18 AM
ImElvis's Avatar
If there was a short, it wouldn't work at all would it? (not in a dick tone lol)
I'll try and swap it out for the other left over tweeter since I'm planning on putting some loctite on all the bolts in the door.. **** rattles so much.
Old Apr 29, 2012 | 02:38 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
Well, the wiring for the tweeter splits at the door, so at least your area for diagnosis of a loose wire is all contained in the door. If it's not in the door itself, it's a problem with the signal not including any of the frequency range that normally would be output by the tweeter.
Amp failing can have a lot of strange symptoms like that.
Old Apr 29, 2012 | 04:46 PM
ImElvis's Avatar
Oo that would be so bad lol as for my stock Bose amp, I did splice into it to hook up a subwoofer setup.
Old Apr 29, 2012 | 04:54 PM
Top Teke's Avatar
You'll be happier with your sound quality if you end up replacing it...
Old Apr 29, 2012 | 07:42 PM
ImElvis's Avatar
Probably.. thanks for the help, everyone!
G35Rican
Jul 31, 2024 01:37 AM
yosip1115
Sep 9, 2015 03:30 PM
socaldavid
Sep 5, 2015 04:35 AM
kevintandmd
Sep 3, 2015 06:41 PM
UT G35
Sep 3, 2015 03:58 PM
