Need Help figuring out wattage on amp
Old Jan 10, 2005 | 10:12 AM
nismoGcoupe's Avatar
Just a little confused im about to buy a phoenix gold zx475ti amp and not sure what kind of wattage I can get out of the amp using it as a 3 channel instead of as a 4 channel. Can some one tell me how much wattage I woud get from this amp if I ran 2 channels at 4 ohms to power 2 6x9's and the other 2 channels power 1 sub at 2 ohms
Here the spec on the amp:
-4 Ch. 500 watt Titanium Amp. W/Free LPL Remote TI500.4 (PreviouslyZX475ti)
-Dynamic Power (IHF-202): 4 ohm Mono 250 x 2 mono 2 ohm Per Ch. 150 x 4 4 ohm Per Ch.
-75 x 4 4 Channel Power Amplifier
-Increased Power Dead Silent Turn on/off
-TAIM Circuitry Variable Speed
-Fan for Reliable Cooling Better Stability
-Ultra Low Loads (2 Ohms bridged)
-Superbrite Tri-LED Power On 24dB Crossover (HP/LP/BP)with Aux Output
-Variable Crossover Range: 40 to 800Hz
-Dimensions: 16.0L x 9.8W x 2.25H
-Freq Response +/-1dB,20Hz to 20 kHZ
-Signal to Noise Ratio (A-weighted) 100dB
-Max Continuous Bridged Power @ 1% THD 250 watts x 2 into 4 ohms @ 14.4 Vdc
-Max Continuous Power per Channel @ 1% THD 150 watts x 4 into 2 ohms @ 14.4 Vdc
-Nominal Continuous Power per Channel @ 1 % THD 75 Watts x 4 into 4 ohms @14.4Vdc
-Power Rating 18 Watts x 4 into 4 ohms @ 12.5 Vdc
Old Jan 10, 2005 | 03:34 PM
CLS2G35's Avatar
What ohm is subwoofer?
Old Jan 10, 2005 | 04:46 PM
I haven't decided yet but I was thinking of a 4ohms jl audio 10w3v2 but depending on how much power I can get out of the amp I might get a sub more powerful
Old Jan 10, 2005 | 04:59 PM
CLS2G35's Avatar
well you gotta remember the W3 is a dual voice coil sub and that changes everything. If you buy a dual 4 ohm sub then you can either have a sub with combined impedence of either 2 ohm or 8 ohm. If you do a W3 with dual 2 ohm then the sub can be either a 1 ohm or 4 ohm sub. I think for this particular amp you'll want to do a dual 2 ohm sub. What you'll need to do is wire up the voice coils in series then run it to the amp. What happens then is the sub presents a 4 ohm load at the amp, but because the amp is bridged mono it will see the load as being 2 ohm. So sub should be getting 250 watts at 14.4v.
Old Jan 10, 2005 | 05:16 PM
so the 6x9's will get 75wx2@4ohms and the the sub will get 250wX1@2ohms if i go with the W3 with dual 2 ohm? is that correct
Old Jan 11, 2005 | 09:57 AM
CLS2G35's Avatar
yes at 14.4 volts.
Old Jan 12, 2005 | 11:05 PM
CLS2G35, what other 2 ohm subwoofer would you recommend to use with my amp that hits hard and dont require a large enclosure besides the jl audio w3.
Old Jan 28, 2005 | 11:23 AM
cls, how many watts would a dual 4ohm sub get?
Old Jan 28, 2005 | 02:13 PM
CLS2G35's Avatar
I'll have to get back to you on that ok?
Picture Share
Feb 4, 2018 12:41 PM
g.spot
May 9, 2016 10:54 PM
DEMoLITIoN
Audio/Video/Electronics
Apr 20, 2016 06:57 PM
AL8782
Oct 3, 2015 10:26 AM
