Amplifier Going To Protect Mode
Old May 11, 2012 | 01:30 AM
NATH_19's Avatar
Need your help audiophiles out there.
I followed this DIY on adding an amplifier to my stock bose.
Did it exactly as instructed:
https://g35driver.com/forums/audio-v...g35-coupe.html
I am running an HiFonics TXi 6406 Multi-Channel Amplifier
Technical Details
Product Features
4/3/2 Channel TXi Series Amplifier
Class A/B Amplifier
85W RMS x 4 chan. @ 4 Ohms
170W RMS x 4 chan. @ 2 Ohms
340W RMS x 2 chan. @ 4 Ohms Bridged
Subwoofers would be 2 10" Kicker Comp 10
The Amplifier turns on properly when I turn on the radio
The problem is it goes to protect mode when I plug in the RCA that I tapped to the wires before the Bose Amp.
If I remove it and turn off the car, the amplifier resets.
Now turn it on again and once you plug in the RCA it goes to protect mode again...
No fuse blown or anything like that.
Pls. help
Old May 11, 2012 | 02:32 AM
neo_anderson302's Avatar
Smell it to see if you fired it.
Old May 11, 2012 | 03:58 AM
NATH_19's Avatar
not fried, question is why is it going to protect mode ??
again the DIY was followed.
Old May 11, 2012 | 07:36 AM
Jaemitch's Avatar
You may have a bad set of RCAs.
Old May 11, 2012 | 09:21 AM
NATH_19's Avatar
I dont think it is because of a bad set of RCA's
If it is then i should also have a problem and it should be affecting the stock system.
If the RCA's are grounded then I would think that sound going to the rear speakers will be affected, but it is not...
Anyone else ??
HELP !!!
Old May 11, 2012 | 11:14 AM
Wrathernaut's Avatar
Gentle Manne of Leisure
Get a 3.5mm to RCA y-cable and plug into a different audio device (iPod, whatever). If it goes into protect mode there, then your problem is probably this:
Those Kicker Comp 10's come in 2, 4 and 8 ohm versions. If they're 2 ohm, then it's instantly going to protect itself from frying when you apply the signal.
Old May 11, 2012 | 11:26 AM
NATH_19's Avatar
I think my subwoofers are 4ohms ill double check.
stupid of me not to think of the load. I will remove the speaker wires first and see it it goes to protect mode when I plug in the rca's.
If it still does I will borrow a different amp and plug my rca. Now if still does then ill double check the rca's itself.
I was up till 2am wiring everything..lol so my analytical thinking is down...
I will advise what happens
Old Jun 6, 2012 | 04:45 PM
NATH_19's Avatar
been so busy and tried to fix this.
I followed your suggestion of use 3.5mm to RCA y-cable and I used an ipod. It worked and my amp did not go to protect mode.
I cannot get any other info about my amp if it accepts high signal input ( factory radio gives high signal right ? )
Do I need to get an LOC ?
Old Jun 7, 2012 | 06:26 PM
NATH_19's Avatar
Anyone ?
Connections dine pre bose amp.
Rcas connected to aftermarket amp hifonics txi 6406
Amp turns on to protect mode once you plug in the rca.
I used a 3.5mm male to rca and plugged to my ipod then to the amp and it did not turn on protect mode.
What do I need to do ? Line output converter ?
What signal does our stock hu produce high or low ? Does it matter ?
I am searching and reading old posts but still confused..
Pls. Help
Old Jun 8, 2012 | 10:05 AM
Mobydick's Avatar
Did you cut the RCA cables and then splice them to the wires? Double check your splice to make sure positive to positive n negative to negative. I used the same DYI instructions as you did, only I used a LOC.
Old Jun 8, 2012 | 10:30 AM
NATH_19's Avatar
I spliced mine before the bose amp.
Did you spkice your before or after the bose amp ?
which loc did you use ?
how was it connected ?
Old Jun 8, 2012 | 01:05 PM
Mobydick's Avatar
I spliced mine from the speaker wires to the rear speakers.
I don't remember what brand the LOC was but I got if from Best Buys.
Connection is simple: 4 wires (left and right speakers) in and 2 RCA out.
Old Jun 8, 2012 | 01:20 PM
Mobydick's Avatar
Try connecting the RCA one at at time to your amp to see if both sides trip the amp. If both sides trip the amp then you probably crossed the wires or the level coming from the HU is high.
Old Jun 8, 2012 | 04:42 PM
NATH_19's Avatar
So you went and tapped after the BOSE.
Ill try that this weekend with and will buy an LOC
I did try one RCA at a time and it trips the amp. I will check again and see the colors of the wires which I tapped in before the AMP is correct.
If all is correct and the level coming from the HU is high, what would fix this ?
Old Jun 8, 2012 | 05:09 PM
Mobydick's Avatar
If the wiring is correct and considering that your amp is good, the LOC should fix the problem.
BTW, are the speakers connected to the amp? Try disconnecting all the speaker wires.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
suby01
Not G35 Related
May 25, 2016 03:07 PM
master111
Sep 25, 2015 08:32 PM
Cbohannan101
Sep 12, 2015 10:32 PM
FRUG35
Sep 11, 2015 03:07 PM
