Am I due for a new radio?
Old May 15, 2012 | 04:06 PM
cc1012's Avatar
Hi guys,
Im not the most active member on the board but Im having some issues with my G. I have a 2007 fully loaded g35 coupe 6mt. In the past few months my bluetooth doesnt work at all, it constantly disconnects from my iphone and my steering wheel radio controls work every now and then. Is it time for a new radio? Do I need a new bluetooth unit to fix that issue? Should I take everything apart and see if everything is plugged in tight?
-Chris
Old May 15, 2012 | 07:39 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
The steering wheel controls go through the bluetooth unit before the headunit, so if there's something going wrong with the bluetooth, that's a very likely cause of the problems you're seeing.
It could be a simple loose connection on the harness, but if it's something more, you'll need a replacement unit. Posting up a WTB might work, as the bluetooth unit's not of much use after you get a new headunit.
Old May 15, 2012 | 07:46 PM
ben's g35's Avatar
if it is the radio, you should not get OEM. just upgrade to an aftermarket .
Old May 16, 2012 | 08:55 AM
cc1012's Avatar
where do they stash the bluetooth unit? is it under the plastic cover next to the spare?
Old May 16, 2012 | 10:56 AM
It's under the rear deck on sedans, and I believe it's by the spare in the coupes.
Old May 16, 2012 | 11:37 AM
cc1012's Avatar
Can anyone confirm where the unit is on the coupes? I found a used bluetooth unit on ebay for $138. But before I buy that i would like to confirm that everything is connected tight.
Old May 16, 2012 | 08:57 PM
Top Teke's Avatar
It's here:
This is underneath a piece of black molding to the left of the spare tire as you look at it. Couple screws to remove for the molding and then you'll find your bluetooth unit.
Old May 16, 2012 | 09:40 PM
blazeplacid's Avatar
if its a late 2007 with the new body style and and new interior, you cant change the factory radio with an aftermarket
Marlin84
Apr 1, 2020 12:52 PM
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
Rinaldi
Dec 2, 2015 05:29 PM
