Does my car have sattelite radio? If so, what steps do I need to take?
Old May 25, 2012 | 02:04 AM
NyCrAzY's Avatar
I just got my 2006 Infiniti G35 SEDAN yesterday.
When opening my glove compartment, I saw that it had a small XM Radio remote.
So I assumed the past owner had sattelite radio ... so with that said, what steps do I need to take? I really want to get sattelite radio because my 6 disc CD changer is broken!
And anyway I can hook up an AUX without removing the whole set?
Thank you guys.
Old May 25, 2012 | 07:22 AM
Wrathernaut's Avatar
Gentle Manne of Leisure
No idea what the previous owner did to hook up the XM radio, so you'll have to do some digging of your own. The factory radio didn't use a remote for the xm, so it wasn't a factory xm adapter installed. If the factory radio's going out, like it apparently is, you're best off just going with an aftermarket radio to get xm.
Old May 25, 2012 | 03:59 PM
NyCrAzY's Avatar
How can I add satellite radio w/o buying an aftermarket unit?
Seems like the car already has an XM antenna on it
Old May 26, 2012 | 05:29 AM
If everything's there, you'd just hit the sat button, which would give you the info needed to activate it, but again, the factory unit didn't use a remote, so I'm not sure what the owner did.
Old May 28, 2012 | 12:24 PM
NyCrAzY's Avatar
I opened up the trunk and it looks as if the wires in the trunk were never touched so I am assuming tye past owner had an aftermarket satellite radio in the car.
Old May 28, 2012 | 04:40 PM
Based on the antenna, yes, but I've told you that a couple times now.
Old May 28, 2012 | 05:32 PM
NyCrAzY's Avatar
Sorry, didnt realize the past post. So what is my best option now? I dont know where to hunt down the antenna wire if I were to buy an aftermarket radio now ..
Best.option to take it.to an audio shop?
Old May 29, 2012 | 05:29 AM
Yeah, there might be an aux input adapter somewhere back there, so all you'd need is an aftermarket xm adapter to go between that and the antenna that's still there.
I'd see if there's a member nearby that can quickly check the back of the headunit for what's hooked up.
If they didn't remove the antenna, they may have left the aux input as well, and just transferred the actual XM unit so they take it in their next car.
Old May 29, 2012 | 11:44 PM
NyCrAzY's Avatar
I took my car to my local audio shop and he said the antenna in the front was an aftermarket right off the bat ...
I took out the factory radio to see what is back there and there is a spare wire (looks like an AUX cable, but a bigger version) just chilling there. Is that supposed to be there or? I don't see any signs of any AUX cables around the area.
I should also note my car doesn't have a SAT button, but has the Radio button instead.
And it's not even a bose system either ... just factory.
arora_g35
Apr 16, 2026 02:52 PM
mike730
Jan 12, 2018 04:25 PM
realtalk21
Jul 20, 2015 09:07 AM
