Illumination and brake lights not turning on
Old Jun 10, 2012 | 06:05 PM
pmoradi2002's Avatar
I recently installed a double din in my 2003 sedan, however last night noticed that the dash lights and tail lights were not turning on at night. I found that a wire from the radios wiring harness was exposed and I'm guessing caused a short. Covered it up and went to look at the fuses however no fuses were blown out. I'm kinda stuck now and don't know where to look
Old Jun 10, 2012 | 07:16 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
check all 3 fuse boxes.
Old Jun 10, 2012 | 07:42 PM
I'm only aware of the fuse box by the emergency brake and the other one in front of the battery, where's the third one? Any idea which fuse I should be looking for?
Old Jun 11, 2012 | 03:05 AM
There's two in the battery box. Use a multimeter and check 'em all. Visual checks can miss things.
Old Jun 11, 2012 | 06:56 PM
Took the car to two mechanics and an electrical place. All fuses were good and they didn't know what could be the problem. Any ideas before I throw money at someone for an easy fix?
Old Jun 12, 2012 | 10:12 AM
I'd double-check with this thread, as you're definitely experiencing similar symptoms.
https://g35driver.com/forums/audio-v...use-blown.html
Is it because you used the wrong illumination / dimmer wire on the radio?
Old Jun 12, 2012 | 12:38 PM
Thanks for the replies, sure enough I went to check the fuses myself and found the tail light fuse blown. That third fuse box is way in there, took me quite some time to find it. All is good now, I can't believe 3 mechanics couldn't figure that out.
Old Jun 12, 2012 | 01:34 PM
Mechanics < Message Board Trolls
Luisgalvan33
Jul 19, 2018 08:16 PM
mike730
Jan 12, 2018 04:25 PM
MsFitFern
Aug 9, 2015 02:58 PM
ddietz97
Jul 26, 2015 06:16 PM
Lsantana757
Jul 20, 2015 09:08 AM
