OEM navi problems
Old Sep 20, 2012 | 12:22 PM
Dablakbradpitt's Avatar
OEM navi problems
I drive an 04 6mt coupe. Recently got the 6.6 DVD for the navi. In used to navi as I own a 06 fx also but gave it to my wife. Now I'm driving the coupe and when I try and use the navi by entering street address, it always says state "California" I try n click it n it says no data found. My question is how do it change the region? I can't figure it out at all. On the fx it's pretty simple just change the region n I can navigate. Not this one. Please hell me out. Thanks
Old Sep 20, 2012 | 08:29 PM
Frankieg35's Avatar
Did u drive it after u put the new disk in, when I got mine it came up as California, I drove down the street and it found where I was..
Old Sep 20, 2012 | 09:23 PM
Yeah the navi shows where i am, but when i press route to enter an address it says state:california. need to know how to change that to new york.
Old Sep 23, 2012 | 10:37 AM
Bump
Old Sep 26, 2012 | 09:15 PM
still need help, the navi show that im in new york. That is correct. here is the problem, when i enter a new destination and click on state, no other states pop up. help me!
Old Oct 5, 2012 | 01:26 PM
dj714's Avatar
Bought a used 06 coupe and it came with a burned copy of the maps DVD and it also shows me as being in NY. Plus even when I used the locate me option it states that it’s not in range, might there be something wrong with my gps antenna?
Old Oct 5, 2012 | 02:11 PM
I fixed it. Must update settings DVD first. It's the DVD u put in the car before u put the map DVD.
Old Oct 5, 2012 | 02:20 PM
dj714's Avatar
Ran the self diagnostic test on the GPS and the only one that came back with an error was the GPS antenna. Also my gps location indicator is red.
Could this be my antenna or need a update settings DVD first?
Old Oct 5, 2012 | 05:58 PM
Drive around for like 5 minutes. allow the sat to locate you. should be green in about 4 minutes. if not then update ur navi. what version are u running on now?
Old Oct 5, 2012 | 06:00 PM
dj714's Avatar
I think it's been on red since a I traded for the car. It's a burnt copy of the 7.5
Old Oct 5, 2012 | 08:01 PM
cvipgo's Avatar
you are using wrong version -so you got burnt with it.
Old Oct 7, 2012 | 04:45 PM
dj714's Avatar
What version should I be using? Also would I also need the set up DVD?
Old Oct 7, 2012 | 05:06 PM
cvipgo's Avatar
6.X versions, x 0 thru 10, latest is 6.10 version
Old Oct 7, 2012 | 05:16 PM
dj714's Avatar
So the 7.5 would be for the 2007?
Old Oct 7, 2012 | 05:32 PM
Don't spend money for no reason. What ever version u r using. Go n try and get the install cd for that version. Each cd has its own install cd where u boot it up to run the DVD u r currently using
