Stereo and A/C controls go dead!
Hello,
About half the time I dive my stereo and A/C controls will go dead. I can still control the stereo volume from my steering wheel, but not the dash.
Just wondering how I can repair this?
Thanks in advance for the help!
It sounds like the board, I have one for sale.. https://g35driver.com/forums/audio-v...dio-parts.html
If it's the control board that's bad, you can replace it, however, it's the bad power circuit in the headunit that probably caused the current one to burn out in the first place. Putting a replacement in will be only a temporary solution until it is also fried.
Best to put your money towards a new aftermarket headunit and the JDM or Metra trim.
Fuses wouldn't cause this problem at all.
JDM or Metra - I need to change my dash?
You only need to change the trim around the radio. Check this post here for an idea of what's involved:
https://g35driver.com/forums/audio-v...urce-list.html
Ok just so I understand this better: (sorry, I don't know much about car audio equipment)
There isn't really away of repairing what I have? ie new board?
If I get the JDM dash do I need the 1:AM/FM Antenna adapter? and my steering wheel controls work so is the 2. Steering Wheel Interface?
Do I use the current circuit board, or does the JDM come with a new one?
If I don't have nav - do I just have to live with the big gaping hole(I'm guessing the stock radio/sound system doesn't fit)?
Thanks,
Thanks,
Thanks,
Thanks,
With the JDM dash, you need the antenna adapter and steering wheel adapter. It will come with a new climate control board, the aftermarket radio takes care of the rest.
There's no hole left behind, your storage compartment transfers right over.
AuAltima3.5
Audio/Video/Electronics
Sep 13, 2015 11:48 AM
eljefe7070g35
Sep 11, 2015 09:28 AM
