Infi's Audio Upgrade
Old Oct 15, 2012 | 12:53 PM
jsm11482's Avatar
Overview
I was never really pleased with the Bose system, and after adding a CarPC, my audio got even worse! So I decided to replace all of the factory audio equipment and get my sound back in check.
I decided on:
I went with Sound Ordnance speakers because they are priced well and should offer me a good bang for my buck. They are Crutchfield's store brand and I do trust them - so hopefully they will work out well for me.
I chose the JBL amp because it is very versatile regarding how it is configured and hooked up, and it is easy to tune. This amp has 5-channel input but can run off of two. You can hook up only the left channels and then set the right and sub channels to run off of the left channel input - convenient! Also, it accepts three levels of input: low, hi and hi-er. This will be good for me since the signal is coming from a PC output. I should be able to get rid of my LOC. The amp also has a cool feature which helps to get it setup just right. They give you a CD that you can play at full volume and then you turn on the gain LEDs and can adjust the gain on each channel until the "GOOD" LED is illuminated. That way there should be no guess work with the gain control.
The Alpine sub was picked because it has a shallow install depth but still packs a punch (hopefully). I am installing it in the factory sub location so an 8" sub is all that I have room for.
KnuKonceptz, I read, sells great wiring kits so I ordered a 4g kit and this wire is THICK. It looks high quality and should do the trick!
While I'm ripping my interior apart, I will be applying poor man's sound deadener - Peel & Seal from Lowes. I hope it will tighten things up a bit.
Speaker Installation: Front Door(s)
Trim panel removed, factory speaker removed.
Inner panel removed!
Peel & Seal applied.
Designed and 3D-printed a custom tweeter bracket to replace the factory bracket.
New bracket installed - fits perfect!
Speaker Installation: Rear Door(s)
Trim panel removed.
Peel & Seal applied and speaker installed.
Close-up of rear speaker, installed.
Tearing the Car Apart
Rear seat removed. Now time for the shelf.
Rear shelf removed. Dusty!
Wiring
Getting ready for the new wire harness (pre-solder).
New wire harness ready!
Factory and new wire harness.
Installing Sub
Sub fits PERFECT. can't even wiggle it. I bolted it down with some #10 bolts and locking washers.
Sub from below. I was worried the interior trim wouldn't fit but it did (you'll see soon).
Sub from above. (+Gary Johnson)
Installing Amp
Amp hooked up in its temporary location - inside the spare tire.
Power and ground running behind the seat to the amp on the other side.
Finished!
Everything's put back together!
Amp mounted + CarPC. Wires visible :-( maybe I will fix it later...probably not!
Removed the Bose tag from the sub grille.
Old Oct 15, 2012 | 02:21 PM
dukehotty's Avatar
subscribed! Which sound deadener did you go with?
Old Oct 15, 2012 | 03:57 PM
jsm11482's Avatar
Peel & Seal (link in original post). It is a roofing product that some say works well for the price as a sound deadener. We'll see.
Old Oct 15, 2012 | 04:03 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
Hopefully you're not anywhere that it gets hot. That stuff is not made to hold its weight in any way, so you could end up with a lump of tar and metal in the bottom of your doors. It's fine for doing floors where gravity works for it, but I'd go with some quality CLD tiles from www.sounddeadenershowdown.com any day.
Old Oct 15, 2012 | 05:02 PM
eggyhustles's Avatar
no offense, but those are **** speakers.
This is a case where the stock bose would sound better..
Old Oct 15, 2012 | 05:48 PM
jsm11482's Avatar
Yeah I've heard mixed reviews regarding heat on these. Maybe I'll have a mess to clean up next summer...time will tell!
Old Oct 15, 2012 | 05:51 PM
jsm11482's Avatar
None taken - I know they're cheap. If I'm not happy with them I'll just switch 'em out later.
I don't think anything I can put in my car audio-wise would be worse than what I'm replacing since I don't have a HU with preamp-out, I was underpowering the Bose amp which gave me very flat music. After getting the new amp installed and the new speakers properly powered, it will sound better than what I had. I plan on posting before/after sound clips.
Have you used this brand before or are you speaking from the specs?
Old Oct 18, 2012 | 01:26 PM
EndurAl's Avatar
I'm interested in how well the Alpine 8" will work free air. Also wonder how well the sub will fit in the stock deck hole.
I put a PG sub as an experiment in my rear deck. The sub worked decent for the brief period it lasted. I'll be putting a JBL GTO 804 in the deck soon, but right now am using an 10" Alpine Type R/sealed box in the trunk.
Old Oct 18, 2012 | 01:37 PM
jsm11482's Avatar
I got it wired up last night and tested it although it's not completely secured yet. For an 8" sub it sounds like it packs a lot of punch! The sub is solid and very heavy, feels like great quality.
It fits like a glove. It slides in easy and there is no wiggle room. The only problem is mounting it, you have to drill new holes - from the bottom. I did it and my alignment was off so I need to widen the holes and then use bolts instead of screws to secure it. I haven't put the trim back in the trunk or on top of the shelf. I think the shelf trim will fit fine but the trunk "ceiling" trim may hit the underside of the sub - we'll see.
Old Oct 18, 2012 | 01:44 PM
EndurAl's Avatar
Install sounds pretty much the same as the PG sub I put in. Fit great in the deck but getting the sub mounted was a colossal PITA. I also used bolts to mount mine.
Old Oct 18, 2012 | 01:46 PM
jsm11482's Avatar
Install sounds pretty much the same as the RF sub I put in. Fit great in the deck but getting the sub mounted was a colossal PITA. I also used bolts to mount mine.
Cool, I'll post pics when I finish securing it...probably tomorrow. I worry about fixing rattles now!
Old Oct 20, 2012 | 09:53 PM
jsm11482's Avatar
Initial post updated with pics. Project complete! (Adding bass control **** next week, though.)
Old Oct 20, 2012 | 11:29 PM
I also did this. F' the bose!
Old Oct 20, 2012 | 11:53 PM
EndurAl's Avatar
I also ended up installing my amp (PDX 5) in the same location. I wish the PDX had all the adjustment ***** on top of the amp like the JBL. All the PDX controls are tiny and located on the side of the amp. - makes changing settings a real chore.
Old Oct 21, 2012 | 12:27 AM
jsm11482's Avatar
Yeah, so far this amp is really nice. Very flexible setup!
