iPod straight into bose amp
Old Dec 8, 2012 | 01:22 PM
fitty's Avatar
I asked this question before and it got locked, but mainly because I believe the moderator didn't understand my question.
I want to run an iPod straight into the bose amp. Completely bypassing the stock radio. I do NOT want to use a pac-nis2, oem2, etc.
Is there a way to wire up something straight into the bose amp? Obviously the head unit is sending signal into the amp, which in turn sends it into the speakers so that/s why I am asking.
Would an aux wired into the speaker wire that goes into the amp do the trick? Or would I need a few more things?
Basically
Ipod>*some sort of DIY wiring*>bose amp>speakers.
If you still are confused, then this is how I would do it with an aftermarket amp, since it would be easier.
Ipod > Auxillary cable with 2 male rca on the end > plug aux into iPod > plug rca into amp > music. but obviously the bose amp doesn't have RCA inputs. Thats where I'm stumped
Old Dec 10, 2012 | 09:58 AM
Wrathernaut's Avatar
Gentle Manne of Leisure
No, it won't work well, if at all. The bose headunit sends a differential-balanced signal to the amplifier, which your iPod does not produce, so at best, you'll have a noisy signal with nearly no bass.
Old Dec 10, 2012 | 10:34 AM
g35SedanSC's Avatar
but you can wire subs to the stock head unit before it goes in to the amp...))
Old Dec 10, 2012 | 05:06 PM
If the amp supports differential-balanced signals (like JL Audio amps) then yes, otherwise, you'll get similar audio problems.
Picture Share
Feb 4, 2018 12:41 PM
g.spot
May 9, 2016 10:54 PM
DEMoLITIoN
Audio/Video/Electronics
Apr 20, 2016 06:57 PM
