Aftermarket head unit=no control of a/c
Old Mar 4, 2013 | 04:53 AM
nsfallen's Avatar
i have an 03 g35 and i read the threads about getting the jdm a/c controller if you're getting an aftermarket stereo...thought i found a way around it but i guess not?
my factory stereo stopped working so just as a temp solution I put my kenwood head unit in the upper glove compartment so i could just leave the factory a/c and stereo in their original place. the stereo now works perfect and the non-stereo plugs are plugged back into the factory a/c spots on the back of the factory stereo but i have no control of the heater or a/c now...it kinda just picks a temp, a mode, and a blower level and does it's own thing...
are the stereo plugs also controlling the climate control? i assumed because there are 4 plugs going into the back of the factory stereo, and 2 plugs that you have to use for the aftermarket stereo, then the other two plugs are used for climate control...but they're plugged into their original location and apparently doing nothing in the way of allowing me to adjust the a/c
any help would be greatly appreciated, thanks!
Old Mar 4, 2013 | 11:38 AM
Wrathernaut's Avatar
Gentle Manne of Leisure
The stereo provides the power to the factory climate controls.
I can't confirm it, but I believe that if you run the main power and ground wire to the factory radio, you'll restore the climate controls.
Old Mar 4, 2013 | 01:25 PM
nsfallen's Avatar
i was wondering if it was something like...i dont know who designed this stereo system but it's the stupidest thing i've ever seen
Old Mar 4, 2013 | 03:20 PM
Yep, bad, but much worse because the climate controls and headunit are conjoined instead of separate pieces from the start. Since there was a JDM separate climate controls piece, it seems it would be more cost-efficient to use that one piece in *all* the cars rather than having the joined pieces in some of the JDM and all of the USDM vehicles.
Old Mar 4, 2013 | 09:18 PM
nsfallen's Avatar
i agree but who knows what their reasoning was. i had a 350z before my g35 and it appears to be the same radio that's in the g. the 350z was simple to install a new head unit, but for some reason they felt the need to make the radio and climate control together on the g35
Old Mar 4, 2013 | 09:56 PM
yosip1115's Avatar
I haven't begun with mine because I don't wana buy some $200 piece of JDM plastic
Old Mar 5, 2013 | 12:50 AM
Cangelosijr's Avatar
Ok, I have an 03 coupe as well and I had the same issue. The a/c was stuck on auto @ 70 degrees and I couldn't adjust it and lost the radio as well. I replaced the dash with a double din and there's a relay right behind the controls (its attached to the dash) that when it goes u lose all functions of a/c and radio. My suggestion, buy a aftermarket dash kit for about 250 or replace that control board which could turn into a nightmare. After I replaced mine I had all functions and everything works perfect. Best of luck.
Old Mar 5, 2013 | 07:53 AM
and be careful with your wiring, if u dont know what ur doing you could potentially destroy something else by bypassing ths relay. that lack of resistance on the coil side of that relay could cause a current spike and fry other units.
Old Mar 5, 2013 | 09:13 PM
nsfallen's Avatar
so i can't just splice into the new stereo's power wire and hook it into the pin where it would plug into the back of the stock stereo? along with the ground? this is a temp solution-ish so if in any way possible i dont want to buy the jdm piece. i have it set up where the upper glove box was at and flush with gloss black plexi glass so it looks nice and the stereo works. i just need to get power back to the climate control
Old Mar 5, 2013 | 09:17 PM
I will grab u wiring diagrams tomorrow. If u need help reading them let me know.
Old Mar 5, 2013 | 09:37 PM
nsfallen's Avatar
i appreciate it, thanks!
Old Mar 5, 2013 | 10:48 PM
A/V manual with the diagrams:
http://psedog.com/cars/fsm/g35/coupe/2003/av.pdf
Old Mar 7, 2013 | 01:38 AM
nsfallen's Avatar
got it all wired up. climate control is fully functional and so is the new head unit...still ridiculous that i had to plug the harness into the stock radio, splice the two 12v wires from there to the new head unit, then cut the wires from the stock harness and run them to the new stereo but it does all work now so good enough haha
Old Nov 3, 2013 | 01:37 AM
chandlers_daddy's Avatar
NSFALLEN- wish you would do a YouTube video on how to splice the a/c comtrols
Old Aug 13, 2020 | 01:16 PM
Jackyboy1's Avatar
G35
Dear Wrathernaut
I have been reading your posts and you seem super knowledgable about the wiring issues with the G35. I know I'm responding to an old post but I am having a similar problem and would really appreciate any guidance you can offer. A long story short: purchased JDM DD with A/C control from Ebay (used/good condition). Replaced stock stereo and A/C controller with the JDM. The new Pioneer radio with Apple Play etc is working smoothly. BUT there is no power to A/C controller. Car runs A/C from 'auto' mode but the JDM control unit is not functioning. I have checked fuses and ensured wiring connector blocks are secure. Could I be missing something? Do I need to splice into the new control unit or should that be plug and play?
Thanks in anticipation.
