Car Doesn't start with radio and hvac off???
Old Mar 10, 2013 | 08:17 PM
yoyo221's Avatar
just like the title says!i removed the whole unit so i could install the new Double Din and aftermarket stereo i have ordered but while im waiting for them to arrive i decided to move my car from the driveway spot(because im currently not driving it)to another with the whole hvac and radio units completley off and the car started for a little bit then died,tried starting it again and it just cranks no start..could this be the problem why???is there some type of feedback signal that the whole unit gives in order to start??HELP!!!!
Old Mar 10, 2013 | 08:47 PM
UCIMAplaya2's Avatar
Sounds like a coincidence. I have removed mine and drove around without it while installing my car pc without any problems. I don't think there is anything to feedback from it. I think you might have another problems.
Old Mar 10, 2013 | 09:03 PM
saywat?'s Avatar
u tighten the batt cables back good?
Old Mar 11, 2013 | 10:50 AM
Wrathernaut's Avatar
Gentle Manne of Leisure
Yeah, I'd say battery may have died, there's nothing tying the stereo to the anti-theft or any other system that would keep the car from running.
Old Mar 11, 2013 | 11:20 PM
yoyo221's Avatar
yes well the thing is i never disconnected the battery,i will check batt voltage tommorow and see!
Old Mar 11, 2013 | 11:27 PM
saywat?'s Avatar
That's nuts. Always disconnect the batt. But yea it died then
Old Mar 12, 2013 | 09:16 AM
Lightbulb
It can read 12v all day and not have enough power to start the car.
Also, you really, really should have disconnected the battery when working on the electrical system. If it's not just a low battery, the damage that's causing the non-start was probably because you didn't disconnect the battery.
Old Mar 12, 2013 | 04:49 PM
saywat?'s Avatar
take into the fact that op is a probably quite a noob (since he opted not to disconnect the batt) he likely coulda blew a fuse too that's causing his issue
Old Apr 8, 2013 | 08:54 PM
yoyo221's Avatar
update!!it was the throttlebody-__-..just sprayed it clean and all good!
Old Apr 8, 2013 | 09:50 PM
saywat?'s Avatar
idk man that sounds bs
chinee
Jun 10, 2024 07:48 PM
mike730
Jan 12, 2018 04:25 PM
newg37
Jul 26, 2015 09:32 AM
BlackGee35
Jul 21, 2015 07:24 PM
realtalk21
Jul 20, 2015 09:07 AM
