New System & now Electrical Whine
Old May 22, 2013 | 09:06 AM
  #31
SergeantRed's Avatar
Originally Posted by Wrathernaut
Fuel tank is under the rear seat, but with the seat belt anchor bolts right there too, no reason to use a self-tapping screw. I doubt it's the RCAs as well, but just for any future purchases of people reading this - shielded RCAs > twisted pair in cars 99.9% of the time. (side note - I hate working in a SCIF too.)
As SGTRed said, scrape that paint! it's not exposed to the environment, it's not visible. Scrape it.
If the 4-gauge eyelet doesn't fit, just drill it out a little (use vise-grips or an actual vise to hold it while you drill).
Metal bracket could definitely be the problem. I've never really considered it, since I always mount my amps to MDF, not to metal.
I have had to drill my eyelets as well (the terminal ring, O looking thing at the end of a power or ground wire) There are a couple of things to think about. First, always use a vice grip, if you don't know what it is then google it! Pliers are a bad idea as you more than likely can not put enough pressure on them. Second, not just any drill bit lying around will work! I have learned from experience and destroyed many terminals.... use one that the case says is for metal! It's better to use a smaller bit than a larger bit IMO; simply move it around inside until the hole is large enough. (Holy **** the boss just walked in unannounced, screw him, back to my post) Becareful about keeping the bit on the terminal for too long because they get hot and they will break in two pieces. Kind of like when you take a metal tab and yank it back and forth; the metal gets hot and snaps. Now, lets say you're cheap, don't have the time or just don't f@ckn care....and you find that your terminal ring will be too small no matter what.....cuz let's face it we all are and those flipping seatbelt bolts are thick as all hell.... well... you can always snip the end of the terminal ring to make it into a fork and slide it around the bolt. I've done it before and I'd do it again. Only catch is that you have to ensure the bolt is tight and that the wire WILL NOT COME LOOSE. You could cause arcing if it does and start a fire. Always the potential. This wraps up this short story which was brought to you by Dos Equis, stay thirsty my friends.
Old May 22, 2013 | 09:29 AM
  #32
Originally Posted by DBayPlaya2k3
SgtRed I took a ton of pictures yesterday but my next post following this one may be of more interest.
I wont spam you with pics (83 photos) but just attach the ones you requested.
I assume since the whole secured facility thing that If I attach inline with [IMG] Tags from dropbox you wont be able to see them so ill just upload them directly to G35Driver and attach that way.
Ok looks like I can only upload 5 files directly to G35Driver per post so I had a few more I wanted to show but guess I cant.
I measured the resistance of my old grounding point with a fluke meter. I have pics but cant put them in this post so youll have to trust my numbers.
Attachment 159294
Attachment 159295
Original Ground | Resistance Measured From Bare Metal at Grounding point on Body to Ground input at AMP | 0.4
Attachment 159296
Attachment 159299
New Ground | Resistance Measured From Bare Metal at Grounding point on Body to Ground input at AMP | 0.6
Attachment 159298
Ok, the power looks fine. I think we've ruled out the ground wire. I would try two things now. First, mount your amp with rubber spacers as I have already provided two good reasons for doing so. Next, follow this mini tutorial I pulled from crutchfield which helps you determine if its your RCAs. I'm starting to think it might be. The only other thing I can think of at the moment is your radio ground wire. If you have an aftermarket headunit installed it could be that your ground point isn't working out so well. I grounded mine to the metal bar beneath where the radio sits inside the dash. Anyways, here's the tutorial.
Noise in the patch cables
Noise can be picked up by the RCA patch cables connecting your components. To test this, detach the cables from your amp. (Note: A small number of amplifiers mute themselves when patch cables are removed. To defeat the automatic mute, insert one side (left or right) of a spare patch cable into the amp's left and right input jacks.) Turn on your system and engine. If the noise is gone, reconnect the cables to the amp, and disconnect them from your receiver. If you hear the noise, your patch cables are definitely picking it up. Try re-routing them, taking care to separate them from your power cable by at least 18 inches. Also, newer cars may have a cable that provides power to computers and lights in the rear of the vehicle — make sure that your patch cables aren't too close to this cable.
^Wrathernaut, if it is the RCAs I'm taking 100 points from your reputation for being right, deal with it.
Old May 22, 2013 | 09:32 AM
  #33
DBayPlaya2k3's Avatar
Ok now for the interesting bits.
So I did as much testing as I could last night before it got pitch black and I had to call my gf to come out and use her camera phone l.e.d. as a flashlight to put the car back together.
Test that I did with results.
-TESTING-
1. Insulate the AMP from the car body by using a plastic floor mat (stolen out of GF's Nissan Rouge) | FAIL (Noise still present)
2. Move Ground from original point to lip behind rear seat + Insulate AMP from floor using plastic Floor Mat | FAIL (Noise still present)
3. Disconnect RCA Cables at the AMP Input Side | PASS (Noise Went Away)
4. Disconnect RCA Cables from AMP Input Side & then plug in spare RCA Cable from AMP to AMP (In order to defeat amp auto mute if this feature is present when no input is sensed) | PASS (Noise went away but no audio obviously)
5. Pull out RCA Cables from AMP input partial way so signal still present | PASS (Noise went away) <- This is the most intriguing result. explained below.
I made a video the show what happens when I pull out the RCA's partway from the AMP.
Just enough to transfer signal but not touch the amp body.
I thought it was an AMP Grounding issue with the body but in further testing I found out that assumption was wrong.
In the video linked below I was going off that assumption so just ignore any part about grounding to the body.
Though not in the video I did unmounted the amp from the metal bose bracket and it still had feedback through the RCA's.
So at this point it looks like I will need to Test RCA's at RADIO Side.
Any Comments are defiantly welcome in helping me troubleshoot this issue.
Thanks.
Old May 22, 2013 | 09:52 AM
  #34
[QUOTE=DBayPlaya2k3;6755442]Ok now for the interesting bits.
Not sure if you read my post yet but it seems like we have arrived at the same conclusion
Pickup a pair of twisted RCAs off Amazon!
Is that a power inverter on your passenger floor board? Cuz I'm looking to get one as well. Right now I'm running my Wii off my cigarette lighter but I'd like to hide it more. I'd also like to install my modded Xbox as well or instead It's not overkill!!!
Old May 22, 2013 | 12:41 PM
  #35
[quote=SergeantRed;6755451]
I have about 3 inverters all borrowed from friends at work lol.
I needed something to supply power to the dremal tool (also borrowed) that I was using to grind down the paint to shiny surface for my grounding point.
1 is 400 Watts but only 200RMS it worked well enough for what I needed but its defiantly no name brand cheap foreign brand.
Lol an no its only overkill once you add the big flat screen tv to show off the xbox.
Old May 22, 2013 | 12:42 PM
  #36
Hey guys sorry for the delay in response I had a dept meeting this morning then I have a vendor meeting later this afternoon (sucks cutting into my G35 Forum surfing time lol)
Anyway Wrathernaut and SGTRed
I'm not sure if you were able to watch the video (Sgtred I assume u did since u talked about Inverter lol)
but once you do youll see how awesome this noise problem can be.
Questions
1. Does anyone have an idea why pulling out the RCA's partway seems to stop the electrical feedback? Im not sure if the RCA input Board Area is metal or plastic (hard to tap small area with fingers)
2. Though not scientific seems that the disadvantage of my band aid method of pulling away the RCA's is the sigal is not as strong so my system isnt as loud as it normally is. Does that make sense?
3. I'm all for buying diffrent RCA's . I am not trying to be cheap or anything but I do want to make sure I get a quality set for this issue.
Which RCA's Cables do you guys recommend (id like to know both of your recommendations)?
4. SGT Red you said you grounded radio to metal bar underneath it. I doubt you have pictures but did you use a self tap for this or was there an existing bolt already there?
5. Is there better shelded RCA's than others casue I see braided shielding listed in the description
I would like to take my center console apart today (such a pain to put together lol) but it will depend on what time I get out of work.
If i do I'll try to make another video so that you may observe my testing methods.
Lol at this point im not sure which Id rather have it be
A. Ground to the Radio being crappy
B. RCA's that pick up feedback
C. Defective AMP (I kind of highly doubt this but I guess also possible)
Hopefully I am not missing something else troubleshooting wise. Its funny SGTRed send me that crutch-field troubleshooting tip and that's what I found yesterday before I started troubleshooting (lol and why i did some of the tests I did).
Old May 22, 2013 | 01:21 PM
  #37
Amazon.com: Rockford Fosgate RFIT-16 16 feet Premium Dual Twist Signal Cable: Car Electronics Amazon.com: Rockford Fosgate RFIT-16 16 feet Premium Dual Twist Signal Cable: Car Electronics
<------ creepy, anyways, those are the ones I have. Work great! I used a screw that was already on the metal bar to pinch the ground between a piece of plastic and the metal. It's my car so I shortcut **** that I wouldn't normally do in other people's cars.... I just know it works and therefore I don't care.
First and foremost replace the RCAs don't tear your dash apart if you don't have to, but then again wtf am I saying.... you'd have to anyways to hook up the new RCAs
You are probably right in the assumption that because the RCAs aren't making full contact that the output power is slightly diminished. Kind of like when you pull your ear phone jack out of a music player slowly. The music isn't as loud as when the jack was all the way in <------ that's what she said, right? Anyone? No, ok, I'm out!
Old May 22, 2013 | 03:01 PM
  #38
Wrathernaut's Avatar
Gentle Manne of Leisure
The Tsunami double-shielded ones I use haven't given me any problems.
The whine may just be below the noise floor if the entire audio output is lower with the RCAs not fully inserted.
Old May 22, 2013 | 03:14 PM
  #39
Have you guys seen this video before.
I was trying to understand a little bit more about RCA cables and I came across this in a car audio forum.
Its pretty informative and not long either.
http://www.stevemeadedesigns.com/boa...-twisted-pair/
Old May 22, 2013 | 03:20 PM
  #40
Truth about RCA signal cables - YouTube
Without having watched it I was skeptical because the guy looks like a pedo and he's pointing at, ya well you get the picture....
Old May 22, 2013 | 04:05 PM
  #41
Lol yeah true i see what you mean.
Old May 22, 2013 | 06:02 PM
  #42
Yeah, even with the video it can be confusing. If he had drawn it out a bit clearer it would help.
Old May 22, 2013 | 07:39 PM
  #43
saywat?'s Avatar
id suggest try a different for sure working amp jus to rule out its not an issue with ur amp
Old May 22, 2013 | 09:10 PM
  #44
Alpine PDX??? Very very unlikely
Old May 22, 2013 | 09:48 PM
  #45
saywat?'s Avatar
they cant all be perfect
