OEM Bluetooth still interfering with ASWC-1 Module?
Old 10-19-2022, 10:47 PM
G35_EAZY's Avatar
Originally Posted by Wrathernaut
You never put the ASWC in the trunk. The only thing you do in the trunk is connect those three pairs of wires together. Once those wires are together, the install is just like every other G35 that never had bluetooth.
I have a question and I hope you can help. I have a 06 G35 Coupe with factory bluetooth and navigation. So from what I understand, this is what I have to do correct?
1. Wire AWSC to the M39 harness (as shown in the diagram you put up in another thread). I did this by splicing the M39 harness and connecting the ASWC wires by twisting them. I then added electrical tape.
2. I need to bypass the bluetooth module in order to get the Metra ASWC steering wheel harness to work. I need to connect Yellow with yellow, red with red and green with green in the bluetooth module.
My question after is, will the steering wheel control plug (shown in the picture I attached) need to be plugged in somewhere? Or simply by bypassing the bluetooth module, and wiring the ASWC and M39 harness properly will the ASWC steering wheel controls work?
willdogs
12-08-2015 11:32 AM
miata007
08-17-2015 04:36 PM
noctilucous
2nd Gen (V36) Sedan
08-06-2015 08:47 PM
Quick Reply: OEM Bluetooth still interfering with ASWC-1 Module?
