2005 G35 Coupe
Old Jul 30, 2013 | 02:43 AM
chris.paul's Avatar
2005 G35 Coupe
Recently bought a 2005 G35 coupe because I got a good deal on it. The stereo and the climate control were not working so I got a used unit to replace mine. Looked at DIY videos and installed the used deck into the car today. Turns out the new one doesn't work either. The AC was always on even after I installed the used deck. I disconnected the battery and now it has turned off. Does anyone know what the problem might be? Was there even a problem with the original deck? Both of these decks don't work. Is there a problem with a fuse?
If anyone knows what's wrong please help
Old Jul 30, 2013 | 11:02 AM
Wrathernaut's Avatar
Gentle Manne of Leisure
Well, it's a very common failure of the factory radios. Any replacement is going to be as old as the one you're replacing, so it's possible they're both failed units.
The a/c always on, however, may also be caused by a disconnected cabin temperature sensor, see this thread here for more details:
https://g35driver.com/forums/audio-video-electronics/227673-air-conditioning-issue-after-double-din-install.html
laksjd84
Feb 28, 2026 01:58 PM
R350k5
Oct 1, 2015 08:41 PM
lemmy999
Jul 25, 2015 12:13 PM
AustinErkl
Drivetrain
Jul 18, 2015 05:44 PM
Scredeur4
Steering & Suspension
Jul 17, 2015 06:30 AM
