FS: Custom Sound System 03-07 coupe
$300 - Picked up from 11757 NY
Comes with Alpine Type R 10”, Audiobahn Amp, All needed wires to power it and to tap the bose system in case you have one, remote Bass **** with custom mount for the center console ashtray wrapped in Dinoc Carbon Fiber, all of the panels that you see, and the modified trunk plastics to support the false floor.
I hand-built this from scratch. The end goal was to have full access to the spare trunk, perfect inner cubic space the ten inch sub according to Alpine’s factory specs, while still keep the trunk looking like a subtle blend of Aftermarket and OEM look, yet functional for day to day use. I probably put 60 hours to complete this.
This comes as a complete set. All the plastics to support it, the false floors, the false walls, brackets, screws, etc. Every panel was cut to perfection to the curves on the coupe trunk.
Its made of UltraLite MDF (expensive, really light mdf) for best sounding quality yet weight control. It was then wrapped with OEM color carpet. The industrial thickness fiberglass is supported by DINOC Carbon fiber wrapped MDF and lit up by two V-Leds Led Strips. There is also a computer fan installed under the Amp in case you want the extra cooling (I never turned it on, I over-analyzed it and it ended up being unnecessary).
Installation shouldn’t be hard due to the perfect fit of the materials. It can be installed in a day.
Bottom - Full Trunk Access
Hidden Compartment
[http://www.youtube.com/watch?v=SMZJ_...yer_detailpage
Hidden Compartment
I didn't make the setup. I bought it and sold the car about 2 months later. I was out of town for a few months so if anyone is still interested in it message me again and I will get back to you. This is a pick up only item as there is no possible way I can get this in my current vehicle.
TWASkyliner
Feb 8, 2020 08:00 PM
mjfenix
Aug 17, 2017 05:49 AM
