modifying the 8" boss to a 10" opening?
Old Dec 11, 2013 | 10:29 PM
eggyhustles's Avatar
ah, that's right!
So then baffle behind the seat isn't so bad after all.
I'd def go that route over the 4080 since IB>small sealed
Old Dec 11, 2013 | 11:05 PM
romeow98's Avatar
a rear mounted baffle? what does this entail... my current amp location is right behind the seats... as the only benefit i have with the "seats folding down" is for a ski hole in the centre as there is a large metal rear back rest.
Old Dec 11, 2013 | 11:10 PM
Urbanengineer's Avatar
Ha, owned a sedan for a couple years and never attempted to fold down back seat, also would make sense since the rears have reclining!
Old Dec 11, 2013 | 11:11 PM
Baffle is put behind the seat with subs firing in whichever direction you'd like
Firing directly in the cabin would be better, though.
Pros:
Usually the best for SQ
Endless low end extension
99% trunk space retained
Very low power requirement
Ability to use larger woofers
Cons:
Little more effort needs to be put in vs just throwing a box in the trunk
Old Dec 11, 2013 | 11:20 PM
romeow98's Avatar
good to know =D looks like options the only concern i have with this setup would be possible damage to the subs by items hitting the sub or poking the subs -- but this would be the quickest cheapest way and be able to keep the subs
Old Dec 11, 2013 | 11:21 PM
You can place another board behind this one if you are that worried.
Old Dec 11, 2013 | 11:29 PM
Could also face the cones toward the trunk and put speaker grills on them
Rattles may increase, though.
jeffbdye
Jun 1, 2018 03:51 PM
Claudiu
V36 Brakes, Suspension, Wheels & Tires
Mar 10, 2018 11:38 AM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
Oregon13
Audio/Video/Electronics
Mar 1, 2016 12:06 AM
BradMD_96
Oct 6, 2015 09:31 AM
