Full Digital Gauge readout display
Old Dec 20, 2013 | 10:14 AM
willmkent's Avatar
Hey Guys,
so I really want to have some type of active monitoring system for my G35. However I do not want several gauges in the car. So I found this!
http://www.edgeproducts.com/product.php?pk=145&pvk=405
Opinons are more than welcome, My question is, one of the main things i want to monitor is oil pressure, when plugged into the OBDII will oil pressure show through this device? does the factory ECU have an active Oil pressure monitoring??
Thanks guys
Old Dec 20, 2013 | 01:01 PM
vashawn's Avatar
You do know u can download the app to your smartphone, etc.
And just buy a wifi obd2 scanner, way cheaper than what your looking for.
Hope other can chime on on a good WIFI OBD2 scanner and app to go along.
Old Dec 20, 2013 | 02:15 PM
WhosUrBuddiee's Avatar
There are tons and tons of OBDII displays on the market, really they all do the same thing. Cleanest is to just do a double din stereo and use a ODBII reader as AUX input.
Old Dec 20, 2013 | 11:08 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
It's not wifi, wireless bluetooth.
And it was discussed just the other day in this thread - about $30 for the app and bluetooth adapter:
Originally Posted by https://g35driver.com/forums/audio-video-electronics/435766-garmin-mechanic.html
Sounds like a small taste what you can do with the inexpensive ($5) Torque App for android with an inexpensive (about $25) bluetooth ODB2 adapter.
Old Dec 21, 2013 | 07:45 AM
willmkent's Avatar
I've heard of the apps, but I want so etching that runs by itself, I'd rather not link the phone to it. I like the idea of a double din, but what radio system has these features?? Also, if I hook this up, will the OBD II provide oil pressure reading?
Old Dec 21, 2013 | 09:50 PM
You can get a cheap android tablet to dedicate to it for like $70 all day long. You could put the torque app on the parrot asteroid smart, or pick up one of the cheap Chinese android headunits.
Old Jan 8, 2014 | 10:14 PM
willmkent's Avatar
thats not a bad idea, does the tourqe app give you an oil pressure through the OBD????
Old Jan 8, 2014 | 10:25 PM
bigc's Avatar
Wings Nation
oil pressure readings won't come through the OBDII on our cars...we just have an idiot light. borrow an OBDII scanner from your local autozone/napa/o'reilly's and test it out.
Old Jan 8, 2014 | 10:34 PM
willmkent's Avatar
ok right on. I just want to monitor for possible oil consumption, because I'm unsure about if the car is consuming oil yet or not.
I like the idea for a android tablet with the app. What kind of mounting solutions have people had for this???
Old Jan 8, 2014 | 10:45 PM
Urbanengineer's Avatar
That looks cool, but the apps do a great job for much cheaper.
Old Jan 8, 2014 | 10:49 PM
gary c's Avatar
Never having owned cars without gauges I eventually added a volt and oil pressure gauges to SLICK. It's amazing what oil pressure we get until our cars are totally warmed up, 100 psi at low rpms between gears. That's after she's set at idle in the garage for 5 to 10 minutes. As long as I can see oil pressure, volts and radiator fluid temp from the factory gauge I'm satisfied...Gary
Old Jan 8, 2014 | 11:16 PM
This is 5-10 minutes in Cali weather.
Old Jan 9, 2014 | 08:58 AM
willmkent's Avatar
Oil pressure is important to me for sure. Maybe I will run an oil pressure gauge and use the Tourqe app along side it
Old Jan 11, 2014 | 07:03 AM
Mr. Brooks's Avatar
Thumbs up Sounds interesting
Gary C, why not take pics of what you've installed in slick. So we can have an accurate idea of what your talking about. By the way, I just purchased a ElM. 327 wifi adapter for the engine link app I have on my iPhone. I'll be trying it out later today.
Old Jan 11, 2014 | 10:15 AM
15$ + 10 for the app. Ain't it great?
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
DEMoLITIoN
Audio/Video/Electronics
Apr 20, 2016 06:57 PM
9tray turbo
Sep 29, 2015 10:22 PM
vamarris
Sep 26, 2015 12:56 PM
