03g sedan console on the fritz?
Ok so the console has been busted for about a year now, heat stuck on etc no radio nothing works.
This morning, 14 degrees outside, start the car for warmup, BAM everything works, oh **** time to ramp up the heat lol. BUT no sound from the radio.
I heard some pops a few times and at lunch i hit the area where the factory amp is s fee times, got sound for maybe 10 seconds????
I get home, sitting in the car, heat blasting. Everything shuts off again... What the hell. I can only assume the cold has something to do with it?? But at this point im lost as hell as to whats going on?
This thread here details how to check and clean up the ribbon cable: https://g35driver.com/forums/audio-v...g-channel.html
if it's not that, replacing the radio is the best option, so you won't run into the same problem in the future.
not sure what it would be worth, but i have a factory amp, factory radio, and the factory front bezel stuff with the HVAC controls/buttons, its the silver color, everything works like it should when i removed it yesterday and installed a metra dash kit with a pioneer PRS80 headunit.
make me an offer on it all if you decide yours needs replaced.
matthew
matthew
