OBDII blue tooth scanner
Old Aug 31, 2015 | 06:20 PM
Mr. Brooks's Avatar
Check your phone settings
Old Sep 3, 2015 | 02:51 PM
LoSt180's Avatar
Originally Posted by NYT
I have the ELM 327 mini, but Torque Lite does not work on my '07 G35 Coupe. I'm using an Android based Galaxy S5.
Is the G35 only supported by the Torque PRO version? I don't want to waste $5 on the app if it doesn't work.
Try a different adapter, the build quality on those generic/clone ELM327 devices is all over the place.
I also have a Samsung S5, and my adapter never shows "connected" in bluetooth settings after I pair it. You have to tell Torque what BT device to use. If it still doesn't want to work, try the Lite versions either NDSII or NDSIII (Nissan Data Scan 2 or 3) from the Play Store. If neither of those work, then you probably have a bad dongle.
What error message is Torque giving you by the way? That it can't find the adapter, or that it can't connect to the ECU?
Picture Share
Feb 4, 2018 12:41 PM
9tray turbo
Sep 29, 2015 10:22 PM
