04 G Coupe CD player skipping issue - PA11 installed
Hey guys,
Quick question: My 04 coupe started having issues playing CD, it skips or hick ups while playing a perfectly good official (not burned) CD. I have extended warranty so I think it'll cover the repairs. However, I also have PA11 unit installed (did myself in '07) and here's the question: Will dealership refuse to fix the CD player skipping issue IF I self installed PA11 unit? Can they say it voids the warranty?
Thanks for the input!
Last edited by Wrathernaut; 02-17-2014 at 11:07 AM. Reason: Removing dealership info, just in case.
Hey guys,
Honestly though, these radios fail often enough they probably won't even question replacing another.
The issue started a few years after PA installation.
So that's what I tried doing yesterday (remove the PA11 unit all together) but silly me, broke clock trim piece and decided to hold off. At this point I thought - does it matter if I remove the PA unit?
What I did for now left the cable connected to CD player but removed both PA and iPod cable from the car.
If they ask if he did it, and if he did the CD-changer lock procedure before removal, and he gives a blank stare, they could deny coverage. If he answers that yes, he followed proper procedure:
1. Eject and remove any CDs from the Audio unit (BOSE system).
2. Turn ignition switch OFF. Wait until Audio unit (BOSE system) display is off and mechanism stops moving (mechanism sound stops).
3. Press any one of the disc selection buttons once. When a display shows on the Audio unit (BOSE system), press the same disc selection button again within 5 seconds.
The changer mechanism will lock itself within 10 seconds.
Then they shouldn't be able to blame him at all.
THMotorsports
Midwestern
07-22-2015 10:27 AM
