Sedan front door speakers - coax vs component? Two questions....
Old Mar 17, 2014 | 12:13 PM
TheIronYuppy's Avatar
Hi. 2004 Sedan (non-Bose) with an aftermarket deck.
I plan on slowly upgrading the audio system. To date I've added a JVC double-din deck and a pair of 6 1/2" Clarion speakers in the rear doors as one of the stock rear speakers was torn.
I *may* add a sub and amp and drive all four door speakers with their own amp at some point, but haven't decided yet. In the meantime I want to upgrade the front door speakers.
I took the doors apart the other day and checked-out the stock set-up. I noticed that although there is a tweeter, there seems to be a full range of sound coming from the main speaker.
So, my first question is, if I continue to use the stock wiring, is it necessary to run component speakers in the front doors, or can I run a good set of two-way speakers and either disable the stock tweeters or leave them powered?
My second question is, there seems to be a ton of room behind the interior door panel. If I were to mount the front speakers on a 1/2" or 7/8" adapter ring, is it possible to install a larger speaker in the space? I test-fit a pair of old alpine 6 1/2" speakers I had laying around and they looked almost too small for the holes. Will a 6 3/4" or even an 8" speaker fit?
I'm not an audiophile, nor do I want to spend $$$$ on my system, just a nice clean sound for the occasional extended drive. I'm 46 and have other things to blow money on
Old Mar 17, 2014 | 10:31 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
You can fit some pretty large spacer rings in there, and the holes behind the speaker are also quite large as well. You might be able to pull off an 8" without modification, so long as the magnet on the back wasn't huge. If you have a router of your own, give it a shot.
Old Mar 18, 2014 | 11:25 PM
Thanks. But does it have to be a component speaker?
Old Mar 19, 2014 | 03:37 PM
If you do a coax in there, your tweeter's going to be firing waaay off of optimal, go with a component and replace the factory tweeter.
joedaddy1
Jul 28, 2015 02:58 PM
will091195
Jul 27, 2015 09:19 PM
ClwMike
Jul 23, 2015 12:55 PM
justgotg35
Jul 19, 2015 12:33 PM
