FS[SoEast]: KP Technologies Window UP module NM20
Phase 923478 of my part out - audio & electronics
For sale KP Technologies Window-UP module PN NM20
On our cars, we can hold the UNLOCK button to bring the windows down, but we can't make them go back up!! with this module, UP isnt a problem!
Instruction manual : http://www.kptechnologies.com/docs/N...stallation.pdf
SOLD + PP if applicable
It is fairly simple.
You have to remove two guard plates and the three screws holding the plastic interior door panel in order to remove the door.
Once the door is off, you locate and isolate 5 wires. If you use the wire connector clips from Home Depot, you won't have to cut any wires (I believe that is the suggested method)
Put the door panel back on and enjoy.
Out of 10, I would say 2-4 in difficulty depending on your patience level.
Adrian
Adrian
BradMD_96
Oct 6, 2015 09:31 AM
Learned Hand
Oct 1, 2015 09:02 AM
