Pioneer AVH-X2500BT and ASWC-1
Old Aug 28, 2014 | 11:06 PM
Cingular's Avatar
I just installed a new radio in my 2004 coupe and everything went fine until I started wiring in the axcess control and I cannot seem to get the steering wheel controls to work. I believe it is my Pioneer radio, I was wondering if anyone knew if the harness for my radio had a SWC wire I could use because the second 3.5mm jack in the back is not used for the SWC like I previously thought.
I have followed these guides.
https://g35driver.com/forums/audio-v...urce-list.html
https://g35driver.com/forums/5738236-post15.html
Old Aug 28, 2014 | 11:30 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
The owner's manual, Page 46. The 3.5mm jack to the right when looking at the rear of the radio, is the wired (steering wheel) remote jack.
Old Aug 28, 2014 | 11:51 PM
Cingular's Avatar
Okay, I have that plugged in and the led is not even on.
The controller wires are connected like the diagram green/white to green, gray/red to red, black to yellow and red to red at the radio. If I wire in the black wire to the other ground running to the radio then it will turn on but will not program (flashed red, I hold up volume
and it will flash green for a second then flash red again slower). I was assuming the radio was the issue not the ground cable... Is there a trick to programming?
Old Aug 29, 2014 | 12:02 PM
Do you have the factory bluetooth adapter?
Did you go with the ASWC-1 or the PAC SWI-PS?
Old Aug 29, 2014 | 03:41 PM
Cingular's Avatar
Im stupid, Everything works now.
Old Aug 29, 2014 | 06:28 PM
So what was it?
Old Aug 31, 2014 | 03:46 PM
Cingular's Avatar
I did not ground the factory yellow wire, I had originally thought it was a ground wire that the harness connected to then I read more and realized they both needed to be grounded.
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
BfloG35
Oct 16, 2015 05:22 PM
Cory Dalton
Sep 23, 2015 08:08 PM
Siciliang35
Sep 18, 2015 11:22 PM
AuAltima3.5
Sep 13, 2015 11:48 AM
