I think I found the navscreen replacement I've been looking for
Old 10-11-2014, 03:55 PM
ihiryu's Avatar
With Llama, you can setup fuzzy logic style controls. For my wife's Tab 4 it has two events.
Event 1 "When charging, turn screen on, and play media"
Event 2 "When on battery power, turn screen off, and pause media"
I have a relay from the stock wiring harness that controls a charger for the Tab. So when the key is on, relay activates the charger, and thus the tablet is charging and it launches Event 1. When the key is off, and the tablet is on battery power, it runs Event 2.
Llama can also activate/deactivate apps as well. So if you want to run Waze, and TetherGPS, you can set it to do so when the key is on. Personally for me, I would leave Waze and TetherGPS running in sleep mode, that way you don't have to bother running it all the time.
Also if you're using an android phone you may want to look into a paid app called "Tablet Talk". It'll allow you to connect your phone and tablet via bluetooth or Wifi. When you get a text message or phone call, it will show up on the tablet. You can answer or reply via tablet. So if you've got media going, and you receive a call, it'll automatically pause it (I use the stock media player along with MX Player for movies and it'll automatically pause both).
  #32
Old 10-11-2014, 05:07 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
Received 1,038 Likes on 611 Posts
Well, it looks like the tablet turns waze off on its own after sleeping for a while, so I don't need to worry about that.
And if I remember correctly from when playing with bluetooth before, my Z110BT headunit will switch from the bluetooth streaming audio to a phonecall automatically.
  #33
Old 10-11-2014, 06:39 PM
ihiryu's Avatar
Ah, yeah didn't realize you had an aftermarket headunit. I thought you were doing a radio replacement. When are you going to have the new charging cable?
  #34
Old 10-11-2014, 08:16 PM
I've got the charging cable already taken care of, thought I'd posted this one - it's a Startech 3 foot left angle Micro USB. I had it for my phone install, but for this tablet, I think you'd be better off going with the RIGHT angle version so that it would be angled away from the power button:
  #35
Old 10-12-2014, 11:46 AM
Okay, so although physical installation went without issues, software remains a hurdle.
1) The bluetooth audio connection with the Pioneer radio connects unreliably. Once connected it's ok, unless interrupted by a phonecall. I'm not sure if this is more the fault of the radio or the Fire. It reconnected to the radio when the radio was powered on only once, besides that one time, it's a lot of poking at the connect screens to get them to pair. I can get around this by connecting into the headphone jack, but doing that won't let me use the steering wheel controls, nor will it pause during a phonecall, so I won't pursue that route, as it's striving for mediocrity instead of anything near an optimal situation.
2) The limited amazon app store is still pretty annoying.
So, I think for now, I'll leave it installed, hoping that somebody roots the thing and gets vanilla android running on it.
  #36
Old 10-12-2014, 12:19 PM
ihiryu's Avatar
Here's an idea
Maybe side load a different launcher?? Like smart launcher or anything like that?
  #37
Old 10-12-2014, 02:22 PM
Here's an idea
I may have just got in on this too early, and will have to wait for the android experts to start hacking this device. The screen is great, the processor is pretty good, and the price is fantastic. I can't see them ignoring it for very long.
  #38
Old 10-14-2014, 09:06 AM
Mustang5L5's Avatar
Interesting idea.
Kinda getting tired of non-touch screen button NAV myself
  #39
Old 10-14-2014, 06:45 PM
chava12's Avatar
By any chance did you figure out how to make the screen go up and down?
  #40
Old 10-15-2014, 08:16 PM
Ok, so quote with a message with youtube links is breaking messages...
With the 05+ there's no trick at all, just plug the gray harness in the back and it works like normal.
Up:
Down:
S 854 (10-15-2014)
  #41
Old 10-15-2014, 08:30 PM
Mustang5L5's Avatar
Looks good.
Weird seeing a Nav screen in a car without the Ikey.
  #42
Old 10-15-2014, 09:41 PM
Originally Posted by Mustang5L5
Looks good.
Yeah, one downside to a 6MT, I suppose.
It actually looks really good if I do say so myself, the phone video doesn't do it justice. I'll get out the real video camera soon and do a more complete demo now that it's put together and I've at least got the tethering issues fixed.
And I'm still trying to think of a good way to utilize the nav button area.
  #43
Old 10-21-2014, 07:13 PM
eswift1983's Avatar
Very cool. I'm trying to find something to mount in the cubby as mine didnt have the nav motor thingy. A Sony xperia z ultra will fit nice and snug. Need nav!
  #44
Old 10-21-2014, 08:57 PM
While the width looks a little too wide -
Sony Xperia Z Ultra dimensions:
Width: 17.88 cm
Height: 9.19 cm
Depth: 0.6604 cm
Navscreen space:
Width - 17cm
Height - 10.5cm
Depth - 3cm
There's a little bit of extra wiggle room, since there's screws about 1cm in the depth dimension that protrude into the navscreen space, so since your Xperia fits between the front opening and those screws, it should be fine. That extra 1cm of height room could even give you space to reach the power button. Something I would I could do more easily with the HD6. The charging dock on the side could also be used instead of a USB connection, but I prefer using the USB with mine, since I can get to the plug fairly easily where it runs down under the shifter trim to plug into my laptop if I need to do some changes not possible through AirDroid.
The Xperia reportedly has GPS, a-GPS and GLONASS. With all three, this thing should work great for navigation, provided it's tethered to your phone or given its own SIM card for real-time traffic and destination searches.
One thing you may want to check is the polarization of the screen if you wear polarized sunglasses (as many anti-glare driving sunglasses are). The Xperia Z2 becomes completely black when in landscape mode when viewed through polarized sunglasses, not sure about the Xperia Z Ultra.
The Fire HD6 works fine with polarized sunglasses.
  #45
Old 10-22-2014, 03:45 AM
eswift1983's Avatar
Width: 17.88 cm
Height: 9.19 cm
Depth: 0.6604 cm
Navscreen space:
Width - 17cm
Height - 10.5cm
Depth - 3cm
Good point on the polarised comment. I don't have a nav so it would be mounted to the back of the cubby door. I believe the cubby is 18cm wide inside.
rezendvous420
05-31-2020 01:26 PM
bTanz
10-15-2015 02:31 PM
Tukeeg35
09-27-2015 12:16 AM
Tukeeg35
Engine - Intake/Fuel
08-21-2015 04:19 PM
Buggzb86
Drivetrain
07-25-2015 11:22 PM
Quick Reply: I think I found the navscreen replacement I've been looking for
