Help with Amp & sub plz!
currently i have a alpine MRD-M500 mono amp
it power around 500w @ 2 ohm
i just brought two new 2005 alpine type R SWR-1022D
they are 10"sub 2+2 ohm Dual Voice Coil
Power Handling Capacity (Peak) : 1500W
Power Handling Capacity (RMS) : 500W
will my amp be under power if i run the two subs parallel @ 2 ohm?
should i just go with only one 4+4 ohm 10" to run @ 2 ohm?
should i get only one 2+2 ohm to run @ 4 ohm?
this is making me crazy!! help!
let me know if u need more info!
Originally Posted by g35john
Just wire each voice coil up in series to show a 4 ohm load. then wire each speaker up in parallel to pressent a 2 ohm load to the amp. It should work fine.
DEMoLITIoN
Audio/Video/Electronics
Apr 20, 2016 06:57 PM
