03 G35 Sedan Adding Sub to Bose *HELP*
Old Jan 8, 2015 | 08:17 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
Originally Posted by Xx AzN xX
Ok to clarify for the last method. All i have to do is splice right rca plug to the two red wires and the left rca plug to the two green wires? No need for the LOC?
No. That would probably damage the amp.
You splice the left RCA to the red and green wires. Red goes to the left RCA tip, green goes to the left RCA outer ring. If that ends up with about half the volume you'd expect, also connect the red to the right RCA tip and green to the right RCA outer ring.
If you're connecting to the red and green wires, you need to set the input level to HIGH on the amp.
mjfenix
Aug 17, 2017 05:49 AM
laksjd84
Jul 24, 2015 05:12 PM
Thunderaan
Jul 22, 2015 07:40 PM
vstypicals
Jul 20, 2015 10:55 PM
