SAT removal for GROM
Old Jan 7, 2015 | 08:25 PM
Vanessarino's Avatar
This is a message from GROM Support:
" When you installed the GROM device did you disconnect the Factory satellite tuner? It has to be disconnected at the tuner itself not at the stereo. If this has not been done please do so this should help with issues you are having."
How do I disconnect the SAT tuner from my 03 coupe?
Im having troubles because sometimes the stereo does not recognize the GROM box.
I removed the SAT plug from the stereo and plugged the GROM cable.
I can play music through my phone now but I can't skip the music using the steering wheel control (all I can do is adjust volume) the "bluetooth dongle" does not work too but I can pair my phone with it, its just that my phone says that music is playing but no music can be heard.
What else should I do? Do I remove the SAT box or whatever? Where is it located?
Old Jan 7, 2015 | 10:14 PM
G2B35AGN's Avatar
It's in the trunk, left side, under the floor board. Just unplug it.
Old Jan 7, 2015 | 10:54 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
The sat box by the spare tire, as part of the metal bracket seen here, it will say SIRIUS or XM on it. (ignore the red box, it's identifying a harness) Just unplug it.
Old Jan 10, 2015 | 02:36 PM
It was already unplugged
And also, when I press the SAT button on the radio, SOMETIMES it says "NO SAT"
Old Jan 10, 2015 | 11:15 PM
.cakestar's Avatar
are you running the most current firmware? I had a lot of issues with not even being able to cycle into the grom unit when using the most current firmware. Try reflashing to an older one. check the unit of the box and email grom and ask which firmware would be best with the model you are using or just keep guessing and checking.
Old Jul 29, 2015 | 03:24 PM
EnCr1pt3d's Avatar
I just installed the GROM AND2 and have the same issues. Do I need to disconnect the SAT harness in the trunk AND disconnect the original SAT connector from the female GROM SAT connector?
I have a '05 5AT Coupe.
Dallsinghjr1
Sep 17, 2023 11:25 AM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
dcsbh1
Oct 1, 2015 03:15 PM
Hogbone
Sep 28, 2015 06:44 PM
