Amp wiring
Old Feb 17, 2005 | 10:22 PM
lucidazn's Avatar
Amp wiring
I am having trouble finding posts on how the amp should be installed. Right now they are connected before the stock bose amp. The bass isn't as loud as it should be. Even my rear deck 6x9's overpower my JL sub. I am running a JL 500/1 amp and a JL 10w6v2 sub. I've followed these instructions from this thread:
https://g35driver.com/forums/showthr...hlight=install
I connected the the wires to the sni-15 then to the wires pre-boseamp. I connected the the wires on the black plug. Orange/Blue bose amp wire to the black stripped/silver LLC wire, White/Blue bose amp wire to the silver LLC wire, solid white bose amp wire to the black stripped/white LLC wire, and solid orange bose amp wire to the solid white LLC wire.
Did I do something wrong with the wire connections? Could the blackstripped wires on the LLC be the negative leads instead of the positive leads? Did I even use the correct wires? I am pretty much confused. Hopefully someone can shed some light on this for me.
Old Feb 18, 2005 | 12:23 AM
GoSooners's Avatar
Most likely, you have your wires switched. The stripped might be negative, usually, stripped wires are neg.
Old Feb 18, 2005 | 02:38 AM
ChuckP's Avatar
i was in the exact same situation as u... check the lil polished input sensitivity **** on the 500/1, u will find that it is turned down, thank me later...
Old Feb 18, 2005 | 10:28 AM
lucidazn's Avatar
Yeah, thanks, that fixed the problem =)
Old Feb 18, 2005 | 07:22 PM
ChuckP's Avatar
No Problem, Enjoy.
Old Feb 20, 2005 | 12:23 AM
MightyG35's Avatar
Does the sedan have a bose amp also. If so where is it located.
Old Feb 20, 2005 | 04:52 AM
lucidazn's Avatar
If the positions are the same, the stock bose amp should be to the left of the spare tire in the trunk under the plastic cover. If you remove the screws and slide the plastic piece out, you should find it underneath.
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
Picture Share
Feb 4, 2018 12:41 PM
g.spot
May 9, 2016 10:54 PM
DEMoLITIoN
Apr 20, 2016 06:57 PM
