front doors, rear doors, woofer?
Old Feb 20, 2005 | 09:34 PM
joerandazzo's Avatar
just wondering if i should tap into the front l/r or rear l/r or wooffer? for adding a amp & sub?
Old Feb 21, 2005 | 08:04 AM
is there a reason why i never get replies to any of my posts???
Old Feb 21, 2005 | 09:16 AM
clokwork's Avatar
Cmon Son!
not as much traffic comes through here as the general forums. just be a little patient.
Old Feb 21, 2005 | 09:33 AM
scoobybri's Avatar
Do you have a Bose? If so, tap the inputs to the amp and connect that to a line level converter. Then RCAs from the line level converter to the amp.
Old Feb 21, 2005 | 12:11 PM
sorry for being bitchy... yes i have the bose system, should i tap into the front doors, rear doors, or wooffer???
Old Feb 21, 2005 | 01:37 PM
scoobybri's Avatar
You should tap the lines that run from the head unit and then into the amp. "After HU but before amp" Those line are high level outputs though so you will need a line level convertor or the high level inouts on your amp...if it has them.
Old Feb 21, 2005 | 01:44 PM
scooby thanks for the reply, but there are a few different lines i can tap into.....
front left
front right
rear left
rear right
wooffer
What pair do you recommend I tap into??? fronts, rears, wooffer?
Old Feb 21, 2005 | 02:58 PM
G35PhatS4's Avatar
G SQUAD
front left
front right
rear left
rear right
wooffer
Yo Joe...
Like said before, just tap the wires after the Hu, before the Bose Amp. If you're going to setup a sub/amp combo only... it's fairly easy.
The Blows amp is located to the left of the spare tire in that box. Remove 3 bolts, and it comes right out. Look up the schematics to find which wires to tap (I tapped the Rear L/R for my sub). It shouldn't matter as the L/R signals are the same from the HU.
Run that tapped signal in to your amp. Depending on what amp you use, you might need a LOC. I used a JL Amp and I used an RCA to tap into the wires, and connected to the JL (no need for LOC).
Now stop being so moody...
Old Feb 21, 2005 | 03:36 PM
scoobybri's Avatar
Here is a link to a good article on this website for an amp install...
Amp Install
Shonuff totally removes the Bose amp which is not what I want to do. I think that the Bose amp is more than adequate to power the existing speakers...at least for me. I just want more bass. So I want to add a sub to my system. Here's how I plan on doing it...
Coming from the head unit are 4 speaker outs, LF,RF,LR,RR. According to Shonuff's install, they are connected to the Bose amp through the blue connector and are color coded as follows.
Head unit output colors
Head Output Front Right + Orange/Blue
Head Output Front Right - White/Blue
Head Output Front Left + White
Head Output Front Left - Orange
Head Output Rear Right + Blue
Head Output Rear Right - Pink
Head Output Rear Left + Teal
Head Output Rear Left - Purple
Remote Wire Light Blue/ Silver
I will use quick splices to "tap" the HU rear speaker output wires without cutting them so the signal to the rear speakers will still feed into the Bose amp as well as into my line level converter(LLC). I am going to be using a
Soundgate Loc4.2 LLC. This will convert the signal from the HU into low level RCA jacks which will feed my amp.
The output from the Bose amp is already filtered for tweeter, mid, and woofer depending on which sets of speakers the channel is feeding. The output from the HU is full range and at a lower power than the signal coming out of the Bose amp. I am hoping that this gives it a cleaner and fuller sound than tapping the speaker wires coming after the Bose amp.
Old Feb 21, 2005 | 07:13 PM
Originally Posted by Babiephat
Yo Joe...
not using a loc.... wouldnt that send hi mid and low signals to your amp??? wouldnt that compromise the sound comming out of your subs??? or does jl audio "slash" work around it?
Old Feb 21, 2005 | 11:22 PM
ChuckP's Avatar
u answered your own question....
Old Feb 22, 2005 | 12:04 AM
guess jl slash series amp works around it.... what up with jl rca to speaker??? where can i but it, or something like it???
Old Feb 22, 2005 | 01:35 AM
ChuckP's Avatar
u gotta cut the rca ends off one end of the rcas....yea....read it slow, ull get it...then just connect it to the speaker wire, make sure u turn ur amp to high level input. Or jl makes a lil converter, but its prety expensive for what it is.
Old Feb 22, 2005 | 08:51 AM
[QUOTE= Or jl makes a lil converter, but its prety expensive for what it is.[/QUOTE]
thought slash series handles the hi level with out a "lil converter"
Old Feb 22, 2005 | 09:44 AM
g35john's Avatar
The easy answer here that I believe you were looking for is... tap the rear speaker wires for the sub signal. Your amplifier will filter out the mids and his withs its cross over. Assuming your amp has a low pass crossover.
