03 coupe, running wires
Old Jan 8, 2016 | 10:52 AM
Siciliang35's Avatar
Im looking for ideas to run wires. Its an active set up
Im gonna have the power wire probably 0 gauge from the battery to trunk
1 -4wire 14 gauge going from each door to trunk
1- 2 wire 14 gauge from each rear speaker to trunk
From the radio to trunk
1 remote wire
1 4 wire rca
1 2 wire rca
And whatever else i need for the back up camera
I never tore this interior apart so i need ideas . I dont want to run to many wires thru the floor trim and have a problem putting the trim on.
What do you guys suggest ? Thanks
Old Jan 9, 2016 | 11:31 AM
Wrathernaut's Avatar
Gentle Manne of Leisure
1 remote wire
1 4 wire rca
1 2 wire rca
Power wire is a no-brainer. Cut a hole and drop it through the factory main grommet that's in the same area as the battery. Use RTV silicone to seal the wire into hole, as runoff from the front windshield can accumulate here, so it's prone to have water come through if you're not sealed.
That drops into the passenger footwell, just run it behind the plastic panels as it comes down and under the carpet. There's a huge channel that easily will take a 0-gauge wire, easily accessed by removing the lower door weatherstripping and kickplate.
That channel will go to the rear seat, where you just run behind the side trim if you want to run the wire to under the rear deck, or under the rear seats if you want to go the the trunk floor. You don't need to remove as much trim as I did here, just pulling the carpet back a little is enough to run the wire.
Once you replace the carpet, there's zero evidence there's wire going through there:
Powered speaker wire, Remote wire and RCAs, just take them through the center console and under the carpet on the driveshaft hump. You have to partially disassemble the center console to run the wires, but it's pretty much all little screws, no fragile clips:
You can also run the powered speaker wire though the corresponding channel on the driver's side the same way you ran the power wire down the passenger side, but there's a lot of space in the center console for wiring, and it's plenty separated from the power wire to alleviate any noise from proximity.
Old Jan 10, 2016 | 05:45 PM
Fkn beautiful answer. I usually run all my wires the same as ur saying to run the power on both sides. Rca included but sometimes have problem putting trim back on...... thanks for your time.
Old Jan 13, 2016 | 10:14 PM
BradMD_96's Avatar
What sort of power is/are your amp(s) supposed to be pushing that you need 0 Gauge wire?
Just wondering because I am installing soon and I have 8 Gauge so wondering if I should get something thicker
Old Jan 15, 2016 | 02:33 PM
If your doing anything over around 400 watts I'd use a bigger wire but its important you get copper wire and not copper clad.
Old Jan 15, 2016 | 03:43 PM
Old Jan 15, 2016 | 10:56 PM
BradMD_96's Avatar
400 watts rms or max?
My amp is 800w max with 340w RMS
Old Jan 17, 2016 | 09:50 AM
[QUOTE=BradMD_96;7039779]400 watts rms or max?
My amp is 800w max with 340w RMS[/QUOTE
Id go with
Stinger SK4641 4 Gauge 4000 Series Car Audio Amplifier Installation Kit* or something like that. Its affordable and good quality. Your probably good with 8 gauge but if u ever want to upgrade ,wich is likely ul be set. Once you start playing with your car it gets easier to one up what you already have
Rawrster
Jan 28, 2016 05:26 PM
MarkeeG35
Engine - Exhaust
Dec 11, 2015 02:28 PM
Just Cruise
Dec 10, 2015 08:48 PM
.cakestar
Dec 10, 2015 08:47 PM
jr91298
Dec 10, 2015 02:53 PM
