Ordered Digital Wheelz 700TSV and AVIC-90DVD/Nav player
#47
Originally Posted by wickedG35
Through the factory speaker system!! The sound from the DVD unit gets transferred to the factory unit via the PAC AAI-NIS unit. You select the DVD source from the factory system through the SAT Button: Simple as that! =)
see i use the SAT button for the XM radio. i was told that i would need to use a FM modulator. i guess i'll find out soon enough.
#49
Originally Posted by DiamondGCoupe
yeh I got my stuff installed, all I can say right now is, PIECE OF ****ING ****!
Brightness=50
Contrast=71
Color=65
Backlighting=99
If your image is still dim or was an off tint, as the whites are not white such as yellow, you most likely have a poor connection with the ribbon cable between the screen and the circuit board on either end of the cable. Or a bad connection from the Pioneer interface box to the monitor. If all this checks good, you may have a hardware problem with the screen or player. It should look as good as mine in the above picture.
Bob
#51
What up guys, sorry i've been outta town for a week now. I just got my navi fixed today everything works. Im having one problem though, when I insert the navigation disk its just says Its loading and nothing happens. Then when I press the eject button for a split second you can see the Navigation screen. Does anyone know why this is happending? My cd and dvd work fine, but the navigation CD just says Loading.. I've let it sit for about 15 minutes and still nothing.
#55
i'm having the same problem but, his solution didn't work for me. are there any other options to get this thing working?
#56
So does anyone have the Avic 90 with an updated map disk? My disk is from 2002, just wondered if the 04-05 disk was any better. I do notice problems with "shortest" routing since some streets are new. Can the disk be copied with a dvd-r? Would pioneer credit you towards a new version if you sent the old one in? Why is the picture so crappy with NAV and perfect with DVD's!?
#57
So does anyone have the Avic 90 with an updated map disk? My disk is from 2002, just wondered if the 04-05 disk was any better. I do notice problems with "shortest" routing since some streets are new. Can the disk be copied with a <a style='text-decoration: none; border-bottom: 3px double;' href="http://www.serverlogic3.com/lm/rtl3.asp?si=24&k=dvd%20r" onmouseover="window.status='dvd-r'; return true;" onmouseout="window.status=''; return true;">dvd-r</a>? Would pioneer credit you towards a new version if you sent the old one in? Why is the picture so crappy with NAV and perfect with DVD's!?
#58
WickedG35 and I installed his navigation system over the weekend and his used AVIC-90 came with both the CNDV-20 disc and CNDV-40MT west disc. We could get the CNDV-20 to boot up but the CNDV-40MT would not, so we determined there must be some kind of upgrade procedure. Any ideas out there? As far as making a copy remember the disc is duel layer 8.5GB, so you will need a DL DVD burner. Also both his NAV and DVD image looked great on his DW 700v screen........
Bob
Bob
#59
Well let me first say im pretty sure a DL Dvd Burner is pretty darn expensive and probably not worth it since a new CD would be ~$100 ( just guessing ).
I just got off the phone with Pioneer Parts. There is no updated CD for the Avic 90 since it is an older model. There is a new CD coming out in the next month or so, by June he thinks called the CNDV 40-R. There will be a West and East coast version, it will have all new updates and new features. Cound't get an exact price but he said it should be around $70-100.
Another heads up, the ribbon cable that comes with the screen is garbage and most likely will break on you. If it does, call Xenarc direct, they will send you a new one ( better quality ) for free. You will just have to pay shipping unless you can wait for ground.
My only complaint with the screen is, it doesn't look like the AVic N1 as far as being nice and clear. I've been told my a lot of people, including my installer and friends, that the screen is just not that great. I'll probably, not soon, find out what other kind of screen will fit perfectly in there and hope that will make a difference. I have the TSV and have not seen a regular screen to tell any difference. Maybe its the glare coating that im seeing bumps with??!? If that makes sense.
For those of you with the TSV, you'll need this http://digitalwheelz.com/DResizer.zip to resize your laptop. Anyone know how to put lyrics on a CD? I want the lyrics of a song to scroll while its playing. Is that possible?
#60
