No power to aftermarket head unit
Old May 9, 2020 | 12:06 AM
kingmiles21's Avatar
G35 Coupe
Did you ever solve this issue? I’m experiencing the same issue as well.
Old May 9, 2020 | 05:53 AM
Scorpi0's Avatar
U are also only getting 2 volts at the wires?
Old Jul 4, 2020 | 09:23 AM
G_zus's Avatar
In the bottom picture the BLUE wire from the PAC side isn’t connected to anything. According to Wrathernaut’s wiring chart that wire should be connected to the RED from the head unit harness. So you’ll have a RED & BLUE from the PAC connected to the head unit RED.
Old Dec 21, 2020 | 12:58 PM
GroceryGetter42's Avatar
g35x
I encountered the same issue recently on a 2006 Minnesota (road salt) g35x. After tearing the dash apart and tracing the voltage drop as far back as I could, reseating the fuse near the battery under the hood fixed it for me. Noticed corrosion on the fuse terminals. Interestingly, the ignition switched +12v was fine, so it must go through a different non-corroded fuse.
Old Mar 15, 2025 | 09:50 PM
ckp g35's Avatar
g35 brembo brake package
what fuse did you reseat
Old Mar 15, 2025 | 10:10 PM
g35x
This was 5 years ago. I don't have the car any more. Try all of them.
e1an
May 26, 2018 12:09 PM
VQPWR
Feb 9, 2009 01:43 PM
Kyosho
Apr 3, 2005 11:18 PM
FrankieBallzzz
Nov 23, 2003 09:03 AM
