2005 g35 coupe stuck on 75 degrees
Dec 28, 2018 | 03:39 AM
I have a 2005 g35 coupe that i just installed the metra double din kit on and now my heater/a/c is stuck on 75 degrees... I looked at the back of the control board and according to metra there should be a jumper on option 1... in all the other forum posts i have read it says to remove the jumper all together.. Everything else works on the controls except for the tempature up and down. It is stuck on 75 degrees. I have checked the sensor under the steering wheel and that is connected...any help would be amazing...thanks
Reply 0
Dec 28, 2018 | 09:02 AM
Did you try it with the jumper removed?
Reply 0
Dec 28, 2018 | 03:58 PM
Yes, ive tried it with the jumper removed, ive tried it every witch way but cant figure it out...please help
Reply 0
