OEM Sirius tuner question
Old Mar 28, 2019 | 01:08 PM
WoodG35's Avatar
Bone stock G35, got everything but sirius radio. :(
I bought an OEM Sirius tuner for my G35 Sedan but was unable as of yet to find the antenna that goes with it.
It has the green & curry (brownish) plugs on the tuner, the antenna thing I see on some pictures has the 2 plugs.... then goes into a small box and one wire & plug exit the box to the antenna.
I plugged a regular Sirius car antenna into the Curry plug and got nothing but "acquiring" on the radio........
When I plug the antenna into the green plug on the tuner I get all the channels from Sirius and can listen to all the music ok and when scrolling through the stations it displays the channel I am going through.
Once you pick a channel and the music starts playing the radio just shows "antenna" on the display when I think it should display the song title and band name.
Do I need BOTH green & curry plugs on the tuner plugged into an antenna?
Does anyone know what the 2 plugs are for? One is obviously for the satellite antenna but why the second plug? I saw a pic of a Pioneer tuner that says the curry plug is for GPS? Is that if you have navigation maybe?
If anyone knows what I need to do to fix this issue I could use the help or advice. I have scoured this forum and the Sirius / XM forum with no luck.
I think I need something like this..........
If someone had the OEM antenna wiring / adapter I would be VERY interested in buying it!!!!!
Old Mar 28, 2019 | 04:20 PM
MikeG35Coupe's Avatar
20 Year Member
One owner 2004 G35 Coupe 6MT
I don't believe the OEM antenna kits came with that Y-adapter. You can find new ones on eBay pretty cheap. I really can't help other than that, but I've been looking to add a Sirius or XM tuner to my coupe as well so I'm interested to see how this works out for you. I don't drive the car enough to warrant a full double-din conversion.
Old Mar 28, 2019 | 10:53 PM
WoodG35's Avatar
If ANYONE has an OEM tuner in the trunk with the PROPER antenna set up I would appreciate knowing how their's is set up.
I can't seem to find a picture at all of what came in the car originally or what type of antenna to use.....
Old Mar 29, 2019 | 12:14 AM
Wrathernaut's Avatar
Gentle Manne of Leisure
I've got one sitting in a bag I took off of a junkyard G35. I'll get pics tomorrow.
Old Mar 29, 2019 | 02:51 PM
WoodG35's Avatar
That would be amazing, Thank you
Old Apr 2, 2019 | 01:51 PM
scumbagsleeper's Avatar
1990 Mustang GT - 351W Lightning bored/stroked 383CI TFS heads 78mm Turbonetics huricane
My car has the satellite roof antenna. Never looked for the satellite tuner. Where is it located on the sedan? I put a full din android unit in so I'll probably pull the sat crap.
Old Apr 2, 2019 | 01:57 PM
G2B35AGN's Avatar
It's on the underside of the trunk parcel shelf passenger side (or on the back of the seat frame if dealer installed).
Old Apr 3, 2019 | 09:08 AM
Here is a pic from my 2005 sedan G35X. I would guess that it is stock.
Old Apr 3, 2019 | 09:22 AM
G2B35AGN's Avatar
The factory install on the 2006 is on the underside of the parcel shelf in a bracket with the Bluetooth unit. What you show is the stock dealer install location on the back of the seat frame (at least according to the 2006 TSB I downloaded). I wonder if the parcel shelf location was a subtle difference between 2005 and 2006....
Old Apr 3, 2019 | 09:55 AM
Were you looking at coupe or sedan TSB?
Old Apr 3, 2019 | 10:11 AM
Looks to be identical to the Receptec and Terk splitter.
https://www.amazon.com/gp/offer-listing/B0001KO7U8/ref=dp_olp_0?ie=UTF8&condition=all&qid=1554300839&sr=1-1 https://www.amazon.com/gp/offer-listing/B0001KO7U8/ref=dp_olp_0?ie=UTF8&condition=all&qid=1554300839&sr=1-1
https://www.ebay.com/itm/New-RecepTe...4AAOSw2nNZ8lmY
Pulled it out of the trunk on lunch, another 1lb 7oz weight savings!! Another pic:
Old Apr 3, 2019 | 10:43 AM
G2B35AGN's Avatar
It's for sedan. I checked Infinitihelp.com. It's not a TSB, it's an "Accessory Installation Guide." Sorry about that. There's one for 2006 (what I had), but also one for 2003-2005. They look pretty similar at a quick glance, but perhaps some subtle differences.
Link to 2006 guide: https://x.infinitihelp.com/forum/loc...tid=268&id=749
Link to 2003-2005 guide: https://x.infinitihelp.com/forum/loc...catid=268&id=7
There's also a TSB with "satellite radio antenna installation tips." ITB06-19. It covers from 2003-2007 (though I'm not sure why anyone in this day and age would want to install the butt-ugly Infiniti antenna; I just got a FAKRA adapter and used a modern mini-antenna): https://x.infinitihelp.com/forum/loc...atid=76&id=256
Old Apr 3, 2019 | 10:52 AM
G2B35AGN's Avatar
Referencing OP's initial question, the "curry" plug is for the urban radio signal system. When you are in the city, buildings block the signal. So the satellite vendors in major urban areas set up a system of local antennas that broadcast the signal.
Don't get an OEM antenna. Use the FAKRA adapter you can get on Amazon and plug in a modern mini-antenna. It will utilize both types of signals.
Old Apr 3, 2019 | 11:19 AM
WoodG35's Avatar
Ok, thanks. I was wondering what the terrestrial plug was for.....now I know.
My weird issue is that I get all the channels and everything works fine EXCEPT the radio always displays "antenna".
Was wondering if people with OEM Sirius radios could verify if the radio displays song title / band on the display while music is playing or not?
I was assuming it would but am confused why mine doesn't BUT does pick up the signal 100% and plays the music
Old Apr 7, 2019 | 11:09 AM
telcoman's Avatar
Veteran: Army
When I had my 06 G35 with the Sirius Radio it displayed the song title and artist
It also displayed stock quotes when tuned to CNBC which XM radios do not.
Telcoman
