New radio & amp, still no sound
Old Apr 20, 2019 | 10:42 AM
Justin_kendall's Avatar
G35 coupe
What could be the issue? Installed new factory deck and amp but still don't have sound in my 2005 G35 coupe. Please help
Old Apr 20, 2019 | 10:49 AM
Scorpi0's Avatar
I would assume u didnt install it correctly.
Old Apr 20, 2019 | 11:37 AM
G35 coupe
What could I have done wrong? It's all unplug and plug back in?
Old Apr 20, 2019 | 05:02 PM
Scorpi0's Avatar
Hmm. Pretty difficult to troubleshoot issues like this. Whats the history? Old one was working and just stopped?
Old Apr 20, 2019 | 05:55 PM
G35 coupe
Yea. Everything comes on. Just no sound
Old Apr 20, 2019 | 06:03 PM
Scorpi0's Avatar
Get a cheap little speaker and hook it up directly to one of the speaker wires behind the head unit. See if u get any sound like that.
Old Apr 20, 2019 | 06:20 PM
G35 coupe
OK I'll try that tomorrow when I have more time. U happen to know which wire's are for the speakers.
Old Apr 21, 2019 | 03:40 AM
Scorpi0's Avatar
Lets use the front left speaker. White+ Black-
Old Apr 22, 2019 | 10:29 AM
cswlightning's Avatar
You need to get a a multimeter and start checking connections.
Old Apr 22, 2019 | 11:45 AM
telcoman's Avatar
Veteran: Army
If you touch the speaker wires or the speaker itself with a AA or AAA 1.5v battery you should hear a sound from the speaker if the speaker is good
Telcoman
Old May 5, 2019 | 06:34 PM
G35 coupe
Touched a AAA battery to the speaker wire's and didn't make any sound. So I checked for power and there is no.power to the speakers in the back.
Old May 5, 2019 | 07:28 PM
telcoman's Avatar
Veteran: Army
Touch the + and - of the AAA battery directly to the rear speakers on at a time. If the speakers are good you'll hear a click from each speaker.
Then trace the speaker connections thru the wiring harness's back to the amp
Also you could try a test speaker connected to the speaker output of the amp to confirm sound output from the amp
Use a tone generator and probe to find the open in the rear speaker wiring.
You can find those in the electrical dept of Home Depot
Telcoman
Old May 5, 2019 | 07:29 PM
telcoman's Avatar
Veteran: Army
Out of box failure perhaps?
Does the old one work?
Old May 5, 2019 | 08:21 PM
G35 coupe
No the old 1 didn't work either.
Old May 5, 2019 | 08:41 PM
G35 coupe
Speakers made noise when I touched wires to a better so they are good.
