Added 2 12’s
Old Oct 22, 2019 | 10:14 PM
Harlemkid82's Avatar
Journey Package
Added 2 12’s
What’s good everyone! So I need some help!!! I just installed 2 12’s kicker comps with a 1200.1 kicker amp to my 08 G35 stock radio with Navi an Bose! My problems are that I can’t turn up the volume loud without the amp cutting out! I tried to adjust the LOC an that didn’t work, the gain on the amp is set very low an no bass boost on!! I can play it at a low volume but the subs kicking like they on high volume!! Can anyone help me please!!
Old Oct 23, 2019 | 01:09 AM
Scorpi0's Avatar
Is your LOC hooked up before or after the Bose amp?
Old Oct 23, 2019 | 02:27 AM
Journey Package
After the Bose amp
Old Oct 23, 2019 | 02:28 AM
Journey Package
I saw a few videos on YouTube where they tied right into the woofer wires off the amp!!
Old Oct 23, 2019 | 01:35 PM
Scorpi0's Avatar
I would hook up the LOC before the signal got amplified. I would assume it would give u a more linear volume control on the subs.
Also, why dont u just turn up your speaker volume to whatever u like, and then adjust the gain on your kicker amp accordingly?
Old Oct 23, 2019 | 01:57 PM
eazdaskeez's Avatar
Skip the loc, wire directly to the stock subwoofer Amp.
Old Oct 23, 2019 | 02:01 PM
Journey Package
I did do that! I used a voltage meter an all! But I can’t understand is why the amp cuts out at a loud volume!!! They beat hard as **** on a low volume an with u turn it up loud it starts to act all crazy!! I got a perfect ground to the chassis an the power wire has 100a fuse on it!!
Old Oct 23, 2019 | 03:14 PM
Scorpi0's Avatar
The amp is probably cutting out as a safety feature because its being pushed too hard.
Old Oct 24, 2019 | 10:54 PM
Urbanengineer's Avatar
If you aren't running those plugs to an aftermarket head unit, you'd have to go off the wires for the rear speakers.
How often and at what rate is it cutting out?
Are connections on the amp good?
NaiveRapture
Apr 3, 2009 11:57 AM
silvernole12
Jan 13, 2006 04:27 PM
zimmG35
Sep 27, 2005 09:49 AM
ravegoo35
Aug 8, 2005 10:28 PM
nismoGcoupe
Feb 3, 2005 11:16 PM
